Author Topic: .NET to VB to VBA  (Read 2768 times)
mohnston
  • CAD Programmer
.NET to VB to VBA
« on: August 24, 2009, 06:37:09 PM »
I'm getting tangled up in COM/.NET interop.
I'm updating some code for upgrade to 2010 so I'm running into compatability issues.
I've written a component in C#.NET that I use in VBA to allow dragging (jigging) of entities. So far, so good.
The component works fine when I use it from VBA.
Are you still reading? good.
Now I would like to use the same component from VB (a dll. referenced into VBA) and I'm running into problems.
When I try I get this error message:
Microsoft.VisualStudio.Debugger.Runtime.CrossThreadMessagingException
So . . . I've got a VBA project (dvb) with a reference to a VB program (dll) that references a .NET component (dll).
Plus, the VBA project itself ALSO references the same .NET component.
Is this a recipe for disaster? Or should this work and I'm just missing something?
CAD Programming Solutions
Re: .NET to VB to VBA
« Reply #1 on: August 24, 2009, 06:52:54 PM »
you might try using [STAThread] in your managed code
mohnston
  • CAD Programmer
« Reply #2 on: August 24, 2009, 07:16:00 PM »
said the wise man.
That is exactly what it needed.
Thanks a million.
« Reply #3 on: August 24, 2009, 07:29:25 PM »
Glad it worked  :-)
« Reply #4 on: August 24, 2009, 08:38:19 PM »
Well done.
I imagine a few people would like a cheat sheet for doing this ( in the near future).
