Author Topic: help writing selected lines to file  (Read 2404 times)
andrew_nao
« on: July 30, 2009, 10:43:20 AM »
im tried to modify this lisp to instead of opening a selected dwg
i want it to add selected lines of the file it read to another file
ive seen this explained here before but search isnt turning up anything
can anyone guide me?
TIA
andrew_nao
Re: help writing selected lines to file
« Reply #1 on: July 30, 2009, 10:43:56 AM »
oops here is the dcl file
« Reply #2 on: July 30, 2009, 11:41:47 AM »
You should look at the following lisp functions in the help file. Everything you need to know about writing stuff to a file can be found there.
  • OPEN
  • READ-CHAR
  • READ-LINE
  • WRITE-CHAR
  • WRITE-LINE
  • CLOSE
andrew_nao
« Reply #3 on: July 30, 2009, 03:36:04 PM »
Thanks for the reply
Im looking for guidance on writing multple selected lines to a file
i can get 1 line to write to a file no problem
but adding multiple lines at once to a file is what my issue is
everything i try i get bad argument type stringp
« Reply #4 on: July 30, 2009, 03:40:22 PM »
For multiple lines, just invoke write-line multiple times, maybe through mapcar, foreach or while, for example:
(mapcar
  (function
    (lambda (x)
      (write-line x file))) '("Hello" "Andrew" "Nao"))
(foreach str '("Hello" "Andrew" "Nao")
  (write-line str file))
(setq lst '("Hello" "Andrew" "Nao"))
(while (setq str (car lst))
  (setq lst (cdr lst)))
« Last Edit: July 30, 2009, 04:14:41 PM by Lee Mac »
andrew_nao
« Reply #5 on: July 30, 2009, 03:55:51 PM »
thanks Lee, ill give this a try
but what i was thinking was somehow i have to get my multiple lines into a list and then i could use foreach function
my selection is coming from a DCL list
« Reply #6 on: July 30, 2009, 04:10:53 PM »
You can collect data from a DCL list as described in this tutorial
« Reply #7 on: July 30, 2009, 04:13:21 PM »
If you already have your list, something like this will work
(foreach list_item my_dcl_list (write-line list_item my_file))
andrew_nao
« Reply #8 on: July 30, 2009, 04:40:44 PM »
im stupid  :ugly:
i was trying to turn a list into a list
the foreach works
now i have to get the dcl list to update
that info is in here somewhere i remember seeing it
thanks for the help guys
