Author Topic: 2005 save problem  (Read 1688 times)
2005 save problem
« on: November 01, 2004, 10:45:31 AM »
Has anyone else had a problem with Acad 2005 saving incompatible drawings with 2002 even though the default save is set to 2002?
Thanks,
Ron
Andrew H
2005 save problem
« Reply #1 on: November 03, 2004, 10:59:09 AM »
I have yet to have anytrouble as all our files are saved in 2000 format.
SPDCad
2005 save problem
« Reply #2 on: November 03, 2004, 04:43:24 PM »
I have not had any problems saving to 2000 or 2002 file format from AutoCAD 2005.
Its may be something in your drawings that is causing an error in 2002.
I would audit your drawing if you have not already done so.
If that fails try the old ‘Wblock’, ‘All’.  That always solves the problem for me in the end.
Good luck....
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
