Author Topic: Create a message box  (Read 16508 times)
Chris
« on: July 17, 2009, 04:35:01 PM »
2010 no longer comes with vba, I have a message box that I have been using for sometime that I got somewhere from someone.  Because vba is no longer with AutoCAD (and I dont want to deal with the hastle of downloading the addon for everyone) I need to rewrite the messagebox so I can use it without any vba code.  Possibly a dcl or something.  any suggestions are appreciated.
(defun dwpMsgBox (Title   Message     MsgBoxType  Icon
      /   iicon       imsgboxtype oldvar
      result   strmessage  strtitle
      (setq oldvar (getvar "USERI1"))
      (setvar "USERI1" 0)
      (setq strTitle title
    strMessage
     Message
    iIcon Icon
    iMsgBoxType
     MsgBoxType
      ) ;_ end of setq
      (vla-eval acadobject
(strcat "ThisDrawing.SetVariable \"USERI1\", "
"MsgBox \(\""
strMessage
(itoa (+ iIcon iMsgBoxType))
strTitle
) ;_ end of strcat
      ) ;_ end of vla-eval
      (setq result (GETVAR "USERI1"))
      (SETVAR "USERI1" oldvar)
      result
    ) ;_ end of defun
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
gile
  • Marseille, France
Re: Create a message box
« Reply #1 on: July 17, 2009, 04:55:14 PM »
Does this work ?
EDIT: added (vl-load-com) and corrected `Bbuttons' to `buttons'
;;; MsgBox (Patrick_35)
;;; Val buttons
;;; 0   vlax-vbOKOnly
;;; 1   vlax-vbOKCancel
;;; 2   vlax-vbAbortRetryIgnore
;;; 3   vlax-vbYesNoCancel
;;; 4   vlax-vbYesNo
;;; 5   vlax-vbRetryCancel
;;; 16  vlax-vbKatakana
;;; 32  vlax-vbQuestion
;;; 48  vlax-vbExclamation
;;; 64  vlax-vbInformation
;;; Val return
;;; 1   OK
;;; 2   Cancel
;;; 3   Abort
;;; 4   Retry
;;; 5   Ignor
;;; 6   Yes
;;; 7   No
(defun MsgBox (title buttons message time / return WshShell)
  (setq WshShell (vlax-create-object "WScript.Shell"))
  (setq return (vlax-invoke
  WshShell
  'Popup
  message
  time
  title
  (itoa buttons)
  (vlax-release-object WshShell)
  return
« Last Edit: July 20, 2009, 01:34:43 PM by gile »
« Reply #2 on: July 17, 2009, 05:11:09 PM »
May need to add this:
What are valid entries for [time]
« Last Edit: July 17, 2009, 05:20:07 PM by CAB »
GDF
« Reply #3 on: July 17, 2009, 05:20:41 PM »
So the original MsgBox routine will not work in 2010? $%*&
GDF
« Reply #4 on: July 17, 2009, 05:32:05 PM »
How about this One for 2010?
;; MsgBox(prompt[, buttons][, title][, helpfile, context])
;; Buttons:
;; vbOKOnly    0 Display OK button only.
;; vbOKCancel    1 Display OK and Cancel buttons.
;; vbAbortRetryIgnore    2 Display Abort, Retry, and Ignore buttons.
;; vbYesNoCancel    3 Display Yes, No, and Cancel buttons.
;; vbYesNo    4 Display Yes and No buttons.
;; vbRetryCancel    5 Display Retry and Cancel buttons.
;; vbCritical   16 Display Critical Message icon.
;; vbQuestion   32 Display Warning Query icon.
;; vbExclamation   48 Display Warning Message icon.
;; vbInformation   64 Display Information Message icon.
;; vbDefaultButton1    0 First button is default.
;; vbDefaultButton2  256 Second button is default.
;; vbDefaultButton3  512 Third button is default.
;; vbDefaultButton4  768 Fourth button is default.
;; vbApplicationModal    0 Application modal; the user must respond to the
;; message box before continuing work in the current application.
;; vbSystemModal 4096 System modal; all applications are suspended until the
;; user responds to the message box.
;; Revised (01-27-03) thanks to Ed Jobe's contribution about snagging the return value.
(defun MsgBox (Title Buttons Message / useri1 value)
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (setq useri1 (getvar "useri1"))
  (acad-push-dbmod)
  (vla-eval
    *acad*
    (strcat
      "ThisDrawing.SetVariable \"USERI1\","
      "MsgBox (\""
      Message
      (itoa Buttons)
      Title
  (setq value (getvar "useri1"))
  (setvar "useri1" useri1)
  (acad-pop-dbmod)
  value
;; (MsgBox "Title" 4 "Message")
GDF
« Reply #5 on: July 17, 2009, 05:41:12 PM »
What about using:
 http://www.en.na.mcneel.com/doslib.htm
(defun ARCH:QUESTION  (LN1 LN2 LN3 LN4 / txmsg buttons)
  (setq LN0 "Confirmation to Proceed :\n\n")
  (setq txmsg (strcat LN0 LN1 LN2 LN3 LN4))
  (setq buttons (list "Yes" "No"))
  (dos_msgboxex
    txmsg
    ;;" Arch : Program    Question ?"
    (strcat " Arch Program" " : Question ?")
    buttons
    4))
;;;(ARCH:QUESTION "First Line\n" "Second Line\n" "Third Line\n" "Fourth Line\n")
gile
  • Marseille, France
« Reply #6 on: July 17, 2009, 05:52:01 PM »
time have to be a number (integer or real), if it's greater than 0, the box automaticaly closes after about 1+ time seconds. If it's set to 0 the box won't close while the user closes it by clicking a button.
Another way should be the attached DLL.
Four LISP functions are defined whith .NET:
gc-getfiledlg (gc-getfiledlg title directory filter [multiple])
Returns a list of full pathe(s) it allows a multiple files selection if 'multiple' is specified and not nil)
ex: (getfiles "Select files" "C:\\" "Drawing (*.dwg)|*.dwg|All (*.*)|*.*" T)
gc-getfolderdlg (gc-getfolderdlg message [new])
Returns the full path of the selected (or created) folder
ex: (getfolder "Choose or create a folder" T)
gc-inputbox (gc-inputbox title message [default])
Returns a string (user input)
ex: (inputbox "Qizz" "Question 1 :\nHow old is the Captain ?" "58")
gc-messagebox (gc-messagebox title message [button [icon]])
Returns an integer (see integer codes above), if specified, button and icon requires an integer as above.
ex: (gc-messagebox "Alert" "The file yet exists\nDo you want to replace it ?" 4 48)
The ZIP file countains the DLL and source codes.
Error messages displayed on command line are in French :evil:
« Last Edit: July 19, 2009, 01:17:45 PM by gile »
gile
  • Marseille, France
« Reply #7 on: July 19, 2009, 12:27:53 PM »
Here's a (poor) english translated version.
« Last Edit: July 19, 2009, 03:33:12 PM by gile »
gile
  • Marseille, France
« Reply #8 on: July 20, 2009, 01:39:34 PM »
Chris, or someone else, can you say if the routine posted in reply 2 (using WshShell activeX) works on  AutoCAD 2010 without the VBA module, please ?
Chris
« Reply #9 on: July 20, 2009, 04:48:29 PM »
Reply 2 works great, just had to get the formatting correct
« Last Edit: July 20, 2009, 04:52:03 PM by Chris »
Win 10
GDF
« Reply #10 on: July 22, 2009, 02:45:32 PM »
I get an error with the following (what am I doing wrong?):
(MsgBox "Title" 2 "Message Here" 2)
GDF
« Reply #11 on: July 22, 2009, 02:47:47 PM »
I forgot to modify Bbuttons. works now. Thanks for sharing it.
« Reply #12 on: July 23, 2009, 12:09:47 AM »
My DCL solution. Needs testing. 8-)
[Old Code Removed, see later post]
« Last Edit: July 23, 2009, 11:42:16 AM by CAB »
taner
« Reply #13 on: July 23, 2009, 01:57:53 AM »
牛人啊!佩服!
« Reply #14 on: July 23, 2009, 08:42:16 AM »
Thanks Tanner, I hope to improve it some.
