Author Topic: Getting Blocks with nEntselp?  (Read 2860 times)
« on: July 06, 2009, 10:20:06 AM »
This may be an obvious question, but, whilst in a grread loop, is there any [quick] way to get a block from an (nentselp [pt]) selection?
Thanks,
Lee
Re: Getting Blocks with nEntselp?
« Reply #1 on: July 06, 2009, 11:07:12 AM »
well, it is possible ...
nentselp returns a matrix with the entity at the point and the block entity as the last item in the list IF it is a block. If it is a simple entity, it will not return the name ...
In this simple example, I return the object at the point ... obviously more error checking will need to be done:
(defun getblname (/ grvals gcode gval myent)
;;; infinite grread loop with cursor tracking
  (while (setq grvals (grread T))
    (setq gcode (car grvals) ; get the interface
  gval (cadr grvals)) ; and associated data
    (if (= gcode 5) ; if it is a tracked point
;;; get the entity there, or junk if it isn't a block
;;; error checking needed here
      (setq myent (caar (reverse (nentselp gval))))
Hope you can make use of it
« Reply #2 on: July 06, 2009, 11:26:01 AM »
« Reply #3 on: July 06, 2009, 11:35:32 AM »
Lee,
You did not specify if the user was to PICK the object or pass the cursor over the object for detection.
I assume Keith's example gave you what you needed?  8-)
gile
  • Marseille, France
« Reply #4 on: July 06, 2009, 11:38:51 AM »
You can have a look at gc:AreaGet routine in TotalArea_4.02.lsp.
This routine is used to get a "ToatalArea" bloc reference. It highlights the objets which are linked to block the cursor is over.
« Reply #5 on: July 06, 2009, 06:21:27 PM »
Sorry for the late reply guys,
Keith, that is a great example.
I don't full understand the transformation matrix as, most of the time, nentselp seems to return a list identical to as if the user had used entsel, but after experimenting on a block, I see a whole matrix, with the entity names you mention.
> Gile
Thanks, I had a quick look at your routine as I knew that you would have had to use something to overcome this - but I didn't immediately see your method  :oops:
> CAB
Thanks for the link - nice example. The entity would be picked, but I believe I can use Keith's method either way.
Thanks once again for your time guys,
Lee
« Reply #6 on: July 07, 2009, 12:09:06 AM »
The example I provided will do hot tracking of entitites by simply moving the mouse over them. I have used this in the past for dynamic displaying of entity data without having to select them. This way the user could see object properties with ease.
« Reply #7 on: July 07, 2009, 08:54:00 AM »
