Author Topic: remove similar sub-lists from one list  (Read 1607 times)
robertocuba
« on: June 08, 2009, 11:52:51 AM »
hello:
I'm trying to write a test function which remove similar sub-lists from one liste.
Example: (("m1-1" 10 20) ("m1-2" 50 20) ("m1-3" 45 67) ("m1-1" 10 20) ("m1-2" 2 4) ("m1-1" 20 20))
Must be return:
(("m1-1" 10 20) ("m1-2" 50 20) ("m1-3" 45 67) ("m1-2" 2 4))
Thanks !
Re: remove similar sub-lists from one list
« Reply #1 on: June 08, 2009, 11:58:15 AM »
By "similar" do you mean "comparing only the key, or first item in each sub list" and does "remove similar sub-lists" mean "keep the first instance"?
gile
  • Marseille, France
« Reply #2 on: June 08, 2009, 12:03:19 PM »
Hi
My 'favorite'
(defun remove_doubles (lst)
  (if lst
    (cons (car lst) (remove_doubles (vl-remove (car lst) lst)))
EDIT: I read too fast.
If The answer to MP's questions in "yes", this should be:
(defun remove_same_car (l)
  (if lst
    (cons (car l)
  (remove_same_car
    (vl-remove-if
      (function (lambda (x) (equal (caar l) (car x))))
      (cdr l)
But none of these returns the expected result whith the example list:
(remove_doubles lst) --> (("m1-1" 10 20) ("m1-2" 50 20) ("m1-3" 45 67) ("m1-2" 2 4) ("m1-1" 20 20))
(remove_same_car lst) --> (("m1-1" 10 20) ("m1-2" 50 20) ("m1-3" 45 67))
« Last Edit: June 08, 2009, 12:49:14 PM by gile »
robertocuba
« Reply #3 on: June 08, 2009, 12:27:25 PM »
Why not function with this:
  (if lst
  (princ lst)
(defun c:a ()
  (setq a (list '(("m1-1" 20 20) ("m1-2" 50 20) ("m1-3" 45 67) ("m1-1" 20 20) ("m1-2" 2 4))))
  (remove_doubles a)
« Reply #4 on: June 08, 2009, 12:33:38 PM »
It would appear this is the solution but naming it eludes me:
(defun foo ( lst / a )
    ;; An abused variant of a function penned/posted by Gile
    (if lst
        (cons
            (setq a (car lst))
            (foo
                (vl-remove-if
                    (function
                        (lambda ( b )
                            (and
                                (eq (car a) (car b))
                                (eq (last a) (last b))
                    (cdr lst)
(foo '(("m1-1" 10 20) ("m1-2" 50 20) ("m1-3" 45 67) ("m1-1" 10 20) ("m1-2" 2 4) ("m1-1" 20 20)))
robertocuba
« Reply #5 on: June 08, 2009, 12:42:59 PM »
Yes !
With the foo function is ok !!!!
« Reply #6 on: June 08, 2009, 12:59:09 PM »
A little tighter but not much:
(defun foo ( lst )
    (if lst
        (cons (car lst)
            (foo
                (vl-remove-if
                   '(lambda (b)
                        (and
                            (eq (caar lst) (car b))
                            (eq (caddar lst) (caddr b))
                    (cdr lst)
