Author Topic: Block Colour  (Read 1784 times)
Block Colour
« on: May 19, 2009, 10:16:43 AM »
I am entmake-ing blocks into a drawing, but I can't seem to get the colour of the block correct.
I am using:
(defun mkblk  (col pt rot scl)
  (entmake
    (list
      (cons 0 "INSERT")
      (cons 2 "MYBLK")
      (cons 8 "MYLAYER")
   [color=red]   (cons 62 col)     ; <<---- Colour Argument Set.[/color]
      (cons 10 pt)
      (cons 41 scl)
      (cons 42 scl)
      (cons 43 1)
      (cons 50 rot))))
(defun blkdef  ()
  (entmake '((0 . "BLOCK") (10 0.0 0.0 0.0) (2 . "MYBLK") (70 . 0)))
  (entmake '((0 . "LWPOLYLINE")
             (100 . "AcDbEntity")
             (67 . 0)
             (8 . "0")
             (100 . "AcDbPolyline")
             (90 . 3)
             (70 . 0)
             (43 . 0.0)
             (38 . 0.0)
             (39 . 0.0)
             (10 -9.65926 -2.58819)
             (40 . 0.0)
             (41 . 0.0)
             (42 . 0.0)
             (10 0.0 0.0)
             (40 . 0.0)
             (41 . 0.0)
             (42 . 0.0)
             (10 -9.65926 2.58819)
             (40 . 0.0)
             (41 . 0.0)
             (42 . 0.0)))
  (entmake '((0 . "ENDBLK") (8 . "0"))))
But, even with the block colour argument set to say "green", the block still comes in white (the layer colour).
This may be a amateur question  -  but I haven't done this all that much  :oops:
Cheers
Lee
« Last Edit: May 19, 2009, 10:27:58 AM by Lee Mac »
Re: Block Colour
« Reply #1 on: May 19, 2009, 10:33:43 AM »
Since you are creating the polyline within the block on layer zero, the block will inherit the color of the layer it's placed on.
Re: Block Colour
« Reply #2 on: May 19, 2009, 10:46:57 AM »
Ah, OK thanks Ron.
So if I create it on another layer (not "0"), then I can use the colour argument?
Re: Block Colour
« Reply #3 on: May 19, 2009, 10:53:44 AM »
Also,
if I were to create it on another layer, do I just change the part highlighted in blue, or that in green as well?
(defun blkdef  ()
             (67 . 0)
             [color=blue](8 . "0")[/color]
             (90 . 3)
             (70 . 0)
             (43 . 0.0)
             (38 . 0.0)
             (39 . 0.0)
             (40 . 0.0)
             (41 . 0.0)
             (42 . 0.0)
             (10 0.0 0.0)
             (40 . 0.0)
             (41 . 0.0)
             (42 . 0.0)
             (40 . 0.0)
             (41 . 0.0)
             (42 . 0.0)))
  (entmake '((0 . "ENDBLK") [color=green](8 . "0")[/color])))
Re: Block Colour
« Reply #4 on: May 19, 2009, 10:58:28 AM »
I'd manage the colors of the sub objects bylayer, but you could add the 62 code to them and hardcode the colors. i believe you only have to change the item in blue.
Re: Block Colour
« Reply #5 on: May 19, 2009, 11:02:44 AM »
Lee,
You might also want to check if the block definition exists, or you'll trash any changes made to the block (if any).
(defun blkdef ()
  (if (not (tblsearch "block" "MYBLK"))
    (progn (entmake '((0 . "BLOCK") (10 0.0 0.0 0.0) (2 . "MYBLK") (70 . 0)))
                      (67 . 0)
                      (8 . "0")
                      (90 . 3)
                      (70 . 0)
                      (43 . 0.0)
                      (38 . 0.0)
                      (39 . 0.0)
                      (40 . 0.0)
                      (41 . 0.0)
                      (42 . 0.0)
                      (10 0.0 0.0)
                      (40 . 0.0)
                      (41 . 0.0)
                      (42 . 0.0)
                      (40 . 0.0)
                      (41 . 0.0)
                      (42 . 0.0)
(blkdef)
(mkblk 1 (getpoint) 0 1)
Re: Block Colour
« Reply #6 on: May 19, 2009, 11:28:40 AM »
Yes, I do perform that check - but in the main function, before I call the sub-function to create the defintion.
Thanks for your input Ron, it is much appreciated :)
