Author Topic: Match Properties for Point Descriptions in Civil 3D  (Read 1553 times)
MSTG007
« on: May 12, 2009, 10:05:34 AM »
Is there a command or lisp out there where you can do a "Match Properties" to Points.
Example. Someone Codes in the wrong Point. But I want to place it on the same layer as this one and the same description as the one I previously selected.
Thanks for the help!
Civil3D 2020
Re: Match Properties for Point Descriptions in Civil 3D
« Reply #1 on: May 12, 2009, 10:07:42 AM »
Why not edit the source file (TXT, FBK) and re import the data?
MSTG007
« Reply #2 on: May 12, 2009, 10:16:16 AM »
I have edited alot of my points with measure downs for structure data, and if I wipe it out and reimport again. I have to put all that data back in it. lol
I just thought this might save me some time, rather than manually editing it in cad with pull down golore.....
Civil3D 2020
« Reply #3 on: May 12, 2009, 10:23:11 AM »
Then you need to use another tool to perform this task....
Please see my web tutorial on using XDREFS and stop doing this editing manually....
this is part of my normal course of instruction...
