Author Topic: [HELP]Deal the list with one condition!  (Read 1873 times)
cjw
« on: April 29, 2009, 04:09:51 AM »
(setq LST1 '(((1371.24 720.75 0.0) . 100.408)
     ((1030.31 740.794 0.0) . 80.7133)
     ((1030.31 740.794 0.0) . 40.6777)
     ((655.957 393.364 0.0) . 92.1824)
     ((655.957 393.364 0.0) . 53.9207)
     ((527.273 794.245 0.0) . 116.764)
(setq LST2 '(((1371.24 720.75 0.0) . (100.408))
     ((1030.31 740.794 0.0) . (80.7133 40.6777))
     ((655.957 393.364 0.0) . (92.1824 53.9207))
     ((527.273 794.245 0.0) . (116.764))
How to realize LST1->LST2?
Thanks,it's too hard for me,I think there are good boys can help me here.
mkweaver
Re: [HELP]Deal the list with one condition!
« Reply #1 on: April 29, 2009, 06:31:11 AM »
cjw, are you sure you want the dot in there on the output?  Notice that the output from your setq lst2 strips the dots:
(((1371.24 720.75 0.0) 100.408)
  ((1030.31 740.794 0.0) 80.7133 40.6777)
  ((655.957 393.364 0.0) 92.1824 53.9207)
  ((527.273 794.245 0.0) 116.764)
That said, the following code will return the same thing as your setq lst2:
(defun CondenseList(lst1 / lstsbypoint rtlist)
  (setq
    lstsbypoint (mapcar
  (function
    (lambda(ptinfo1)
      (vl-remove-if-not
(function
  (lambda(pt)
    (equal (car pt) (car ptinfo1))
lst1
  lst1
    rtlist (mapcar
     (function
       (lambda(x)
(CombineCDRs x)
     lstsbypoint
    rtlist (removeduplicates rtlist)
(defun CombineCDRs(lst / rtlist)
  (setq rtlist
  (cons (caar lst)
(mapcar
  (function
    (lambda(pts /)
      (setq rtlist (cons (cdr pts) rtlist))
  lst
rtlist (vl-list*
(car rtlist)
(if (= 1 (length (cdr rtlist)))
   (cadr rtlist)
   (reverse (last rtlist))
;;This removeduplicates code came from a post by MP
(defun RemoveDuplicatesAux ( x )
        ((vl-position x index))
        ((null (setq index (cons x index))))
(defun RemoveDuplicates ( lst / index )
    (vl-remove-if
       'RemoveDuplicatesAux
        lst
And running this with your lst1 returns:
(setq temp (condenselist lst1))
cjw
« Reply #2 on: April 29, 2009, 07:27:13 AM »
mkweaver,
Good job!
Thank you vvvvvvery much!!!!
mkweaver
« Reply #3 on: April 29, 2009, 11:19:02 AM »
You are welcome.
