Author Topic: Auto Save File  (Read 5296 times)
GDF
Auto Save File
« on: April 22, 2009, 04:11:49 PM »
I would like to shorten the time limit that is set by this code for creating an auto save file.
Would I use a smaller or larger number to replace the 1440.0?
;;; AutoSave makes a copy of AutoCAD's current autosave file.
;;;http://discussion.autodesk.com/thread.jspa?messageID=4083449
;;; Getvar using ActiveX
(defun MWE:GetVar  (arglst)
  (vlax-invoke ActiveDocument 'GetVariable arglst))
(defun MWE:AutoSave  (rxrnm cmdinf / ActiveDocument date file1 file2)
  (setq ActiveDocument
         (vlax-get (vlax-get-acad-object) 'ActiveDocument)
        date (MWE:GetVar "date")
        file1 (findfile (MWE:GetVar "savefile")))
  (if (and file1 ASV:TimeToSave (>= date ASV:TimeToSave))
    (progn (setq file2 (strcat (MWE:GetVar "savefilepath")
                               "\\AutoSave "
                               (MWE:GetVar "dwgname")))
           (prompt "\nBacking up autosave file ... \n")
           (if (findfile file2)
             (vl-file-delete file2))
           (vl-file-copy file1 file2)
           (setq ASV:TimeToSave nil)))
  (if (not ASV:TimeToSave)
    (setq ASV:TimeToSave (+ date (/ (MWE:GetVar "savetime") 1440.0))))
  (princ))
;;; Load the AutoSave Reactor
(vlr-command-Reactor
  "Command reactor"
  '((:vlr-commandWillStart . MWE:AutoSave)))
Re: Auto Save File
« Reply #1 on: April 22, 2009, 04:37:20 PM »
Given that 1440.0 is a divisor I'm under the impression making it larger would reduce the interval between saves.
GDF
Re: Auto Save File
« Reply #2 on: April 22, 2009, 04:42:11 PM »
I just wanted to be sure. This code works great and has saved me in the past.
