Author Topic: Edit Attribute Definition??  (Read 3608 times)
craigr
« on: April 01, 2009, 08:50:43 AM »
I am having to do something new to us that I am sure most of you deal with every day.
We were given a outisde company's Titleblock to use for a set of dwgs. I need to fill in the 'Scale' area. What is there now is 'XX'. If I double click on it to edit it, a window comes up labeled 'Edit Attribute Definition'. It won't let me put my scale in the 'Tag:' area, When I enter the scale in the 'Prompt:' or 'Default:' areas and hit 'OK', nothing changes, it stays 'XX'.
So obviously I am doing it wrong. Would someone please explain how I change this to my scale?
craigr
Rob...
Re: Edit Attribute Definition??
« Reply #1 on: April 01, 2009, 08:55:37 AM »
Make the attribute into a block and you will be able to edit it with a double click.
CAD Tech
craigr
« Reply #2 on: April 01, 2009, 09:02:21 AM »
That worked for me.
I was ready to just erase the darn thing and use plain ole text.
One of these days, I will have to learn about those things.
Daniel J. Ellis
« Reply #3 on: April 02, 2009, 03:32:26 AM »
Doesn't exploding an attribute turn it into text?
I remember back on R14 struggling for ages to figure out why all the text label ("LE" on a light, for example) weren't printing, before discovering they were exploded blocks with attributes and loose attributes didn't print back then...
dJE
dJE
M-dub
« Reply #4 on: April 02, 2009, 07:34:43 AM »
The BURST command will do that, but EXPLODE won't.  When you explode an attributed block, you will see the 'raw' attribute definition / tag.
Daniel J. Ellis
« Reply #5 on: April 02, 2009, 08:09:48 AM »
I knew that when one explodes a block attributes become attribute definitions.
I thought that exploding an attribute definition turned it into text though.
dJE
dJE
M-dub
« Reply #6 on: April 02, 2009, 08:16:34 AM »
Not that I'm aware of...
Kate M
« Reply #7 on: April 02, 2009, 01:35:14 PM »
dJE
No, but using the Express Tool BURST on a block will convert its attributes to text. (Doesn't work if the block is already exploded.)
M-dub
« Reply #8 on: April 02, 2009, 01:42:29 PM »
Oh yeah... forgot to mention that you have to have Express Tools for the Burst command...
