Author Topic: Fieldbook causing crash  (Read 1474 times)
SDNiel
« on: March 27, 2009, 02:09:42 PM »
I have a fieldbook file that causes Civil 3D to crash every time.  I brought in the .job file with trimble link and everything worked great.  I try and re-import the fieldbook and get a crash at 16% every time.  I have tried bringing it it with and without edits and get the same result every time.  I have attached the fieldbook file.  I changed the extension to .txt to allow for upload.  Let me know if you can get it to work or if you see any glaring errors in the file itself that may be causing the crash.
Thanks in advance!
Re: Fieldbook causing crash
« Reply #1 on: March 27, 2009, 02:23:18 PM »
I think the wobble is your FBK seems to contain NOTES and other information that should be removed....
as it throws an error here, and suggests SP2.1 be installed.
I am now going to edit the file and remove a little bit of note information and try again...
What what was or is your conversion process?
« Reply #2 on: March 27, 2009, 02:31:12 PM »
This version of your file works.
Prime Services is happy to be of assistance.
SDNiel
« Reply #3 on: March 27, 2009, 03:32:38 PM »
This is the .fbk file that was automatically created upon the .job file import via Trimble Link.  Did you remove anything other than the long note strings?  I was wondering if there was a maximum character length for notes.  I do have SP 2.1 installed.  Thanks again for taking a look at it.
Looking forward to SD in April?
« Reply #4 on: March 27, 2009, 03:38:01 PM »
yes, there were 6-8 NOTES that were at fault in that data.
It maight not be number of characters as the number of spaces in the notes...
Yes, looking forward to SD...as always.... ;-)
