Author Topic: Wire / Cable Label  (Read 6538 times)
M-dub
  • SuperMod
  • I'm never sarcastic...
Re: Wire / Cable Label
« Reply #45 on: November 28, 2011, 10:44:42 am »
This is why I'm afraid of using dynamic blocks.  This wouldn't have happened with our old stuff. :(
It could just be an issue with the multiline attribute, but ... whatever.  This is poopy.
« Last Edit: November 28, 2011, 10:48:36 am by M-dub »
Mike Williams | AutoCAD and Raster Design 2012 | Synergis Adept | Windows 7
M-dub
  • SuperMod
« Reply #46 on: November 28, 2011, 11:06:40 am »
This could be useful for pipe sizes too, can you post what you come with for a solution?
Don't do it!! You know the dynamic block will break  :-P
Jeff H
« Reply #47 on: November 28, 2011, 11:52:28 am »
If it is not that many just go in block editor and for the Attribute set Lock Position = No and move them over?
M-dub
  • SuperMod
« Reply #48 on: November 28, 2011, 11:56:41 am »
Going to look into it this afternoon.  Thanks for the tip.
It's like the multiline attribute got messed up and changed to lower left / right justification from middle left / right.
M-dub
  • SuperMod
« Reply #49 on: December 19, 2011, 09:54:48 am »
So, I just figured out what happened with these blocks.  The ones on the right side of the terminal strips were mirrored instead of being flipped.  I don't know if it was me who did it, but I don't think I would've predicted this behavior.
To fix them, I mirrored them back, did a redefine, then went back and flipped them all and everything is ok.
I wonder if there's a way to prevent a block from being mirrored...
Nibster
  • Autocabbid
« Reply #50 on: December 19, 2011, 01:07:18 pm »
only with a reactor to filter out those blocks
XP x64 pro SP2, E8500 @ 3.16GHz, 8GB RAM, & A2010 w/ 3D navigator & nostromo n52
"Nobody ever knows who I am." ~anonymous
M-dub
  • SuperMod
« Reply #51 on: December 19, 2011, 01:25:53 pm »
That's what I was afraid of.
Oh well... I just hope I can keep this in mind for future reference.
M-dub
  • SuperMod
« Reply #52 on: December 19, 2011, 01:29:07 pm »
On second thought, what do you guys think of adding an invisible attribute reminding users not to mirror that block?
A bit nasty, but might get the job done.
M@yhem
  • Pain is temporary. Quitting is forever.
« Reply #53 on: December 19, 2011, 01:43:39 pm »
Hard to see if it's invisible, dontcha think?
M-dub
  • SuperMod
« Reply #54 on: December 19, 2011, 01:49:31 pm »
Not when you insert it or when you're editing the attributes...
« Reply #55 on: December 19, 2011, 01:59:06 pm »
You could simply redefine the mirror command to filter out the blocks. At a previous job we did this to prevent certain blocks from being mirrored. Of course the default command can always be called from lisp so it isn't 100% fail-proof.
You could create a custom action in a redefined mirror command that flips the block instead of mirrors it then it would be seamless to the user.
Jeff H
« Reply #56 on: December 19, 2011, 03:23:15 pm »
Or
 ATTDISP = ON
or
ATTMODE = 2
M-dub
  • SuperMod
« Reply #57 on: December 19, 2011, 03:46:48 pm »
Or
 ATTDISP = ON
or
ATTMODE = 2
Ok, ya got me.  If people are messing around with those variables, they're going to have more than just this block screwed up.  We've got a LOT of blocks with attributes.  Several with invisible attributes...
