Author Topic: Increment Number  (Read 2618 times)
DanB
Increment Number
« on: March 03, 2009, 03:29:36 PM »
Feeling very rusty and haven't done any "lisping" in a long time so be kind...
Part of a larger routine, I need the output to be in the following format: anything less than "10" should read 001, 002, 003, etc. and <=10 should read 010, 011, 012, etc.
Because of the need to have (setq cnt (1- cnt)) - dealing with a list of numbers in routine - the entry "10" sneaks by and becomes "0010" - think I am missing something simple here.
(defun c:test (/ )
  (setq cnt (getint "\nEnter Starting Number: "))
  (setq cnt (1- cnt))
       (if (<= cnt 9)
        (setq txt1 (strcat "00" (itoa (setq cnt (1+ cnt)))))
        (setq txt1 (strcat "0"  (itoa (setq cnt (1+ cnt)))))
  (princ txt1)
Won't be able to check back until tomorrow - thanks for any feedback.
Dan
Re: Increment Number
« Reply #1 on: March 03, 2009, 03:42:11 PM »
Another way
(defun c:test (/ )
  (setq num$ (strcat "000" (itoa cnt))
        num$ (substr num$ (- (strlen num$) 2)  3)
  (princ num$)
« Reply #2 on: March 03, 2009, 03:54:26 PM »
With a subroutine.
(defun c:test (/ )
  (princ (padL (itoa cnt) 3 "0")) ; pad with 3 zeros
  ;; CAB 03/03/09
  (defun padL (word len chr$ / chr# pad)
    (setq chr# (ascii chr$))
    (repeat (- len (strlen word)) (setq pad (cons chr# pad)))
    (strcat (vl-list->string pad) word)
« Reply #3 on: March 03, 2009, 04:25:03 PM »
I've had variants of these general purpose justify/pad functions for years. Use / abuse to suit:
(defun lset ( str white len )
    ;;  left justify str, padding the result with
    ;;  white chars for a total string ength of len
    ;;  (lset "left" "_" 10) => "left______"
    (while (< (strlen white) len) (setq white (strcat white white)))
    (substr (setq str (strcat str white)) 1 len)
(defun rset ( str white len )
    ;;  right justify str, padding the result with
    ;;  (rset "right" "_" 10) => "_____right"
    (substr (setq str (strcat white str)) (- (strlen str) len -1))
In your case: (rset (itoa cnt) "0" 3)
DanB
« Reply #4 on: March 04, 2009, 09:25:47 AM »
Time permitting, I will take a look today at working these into my routine. Thanks for the replies.
