Author Topic: smart array  (Read 3790 times)
rhino
smart array
« on: February 27, 2009, 10:46:10 AM »
hello all,
This routine uses the array command to array objects with the following enhancements:
- Calculates offset distance between 2 points
- Arrays objects on an inclined axis
I'm new to this whole autoLISP thing and just starting to get 'understand'  :ugly: the code.
;  Smart Array - Enhanced Array Maker © CJC aka 'RHINO' 2009 ;
; This routine uses the array command to array objects with the following enhancements: ;
; - Calculates offset distance between 2 points ;
; - Arrays objects on an inclined axis ;
(defun c:sa (/) (c:smart_array))
(defun c:smart_array (/ obj mode typ hasangle qtx l dist_X dist_Y qty w ent en_typ vert tmp )
;  Variables & Error Handler ;
  (setq oldce   (getvar "cmdecho")
oldosmd (getvar "osmode")
oldangd (getvar "angdir")
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (setvar "angdir" 1)
  (setq olderr *error*)
  (defun *error* (errmes)
    (princ
      (strcat "n\Execution of Smart_Array halted by the following error: "
      errmes " **System variables have been reset**\n"
    (setvar "cmdecho" oldce)
    (setvar "osmode" oldosmd)
    (setvar "angdir" oldangd)
    (setq *error* olderr)
    (prin1)
;  Get User Input ;
  (setq obj   (ssget)
  (while (null obj)
      (princ (strcat "\n*Nothing Selected* "))
      (setq obj (ssget)
  ;(command "undo" "mark") ; set an undo marker to if user wants to undo array
  (initget 0 "Calc Mnl")
    (setq mode  (getkword "\nEnter Mode for array [<Calculate points/distance>/Manual]: "))
      (if (null mode) (setq mode "Calc"))
  (initget 0 "X Y Grid")
    (setq typ (getkword "\nEnter the type of array [<X axis>/Y axis/Grid]: "))
      (if (null typ) (setq typ "X"))
  (initget 1024 "Yes No")
    (setq hasangle (getkword "\nAre the objects on an inclined plane? [Yes/<No>]: "))
      (if (null hasangle) (setq hasangle "No"))
;  Evaluate user input ;
  ; evaluate array mode and set values
    (if (= mode "Calc")
        (if (= typ "X")
    (initget 1)
    (setq qtx    (getint "\nEnter Quantity on X axis: "))
    (setvar "osmode" 191)
    (initget 1)
    (setq l      (getdist "\nDistance on X axis or click points: ")
  dist_X (/ l qtx))
    (setvar "osmode" 0)
(if (= typ "Y")
    (initget 1)
    (setq qty    (getint "\nEnter Quantity on Y axis: "))
    (initget 1)
    (setq w      (getdist "\nDistance on Y axis or click points: ")
  dist_Y (/ w qty))
    (setvar "osmode" 0)
(if (= typ "Grid")
    (initget 1)
    (initget 1)
    (initget 1)
  dist_X (/ l qtx))
    (initget 1)
  dist_Y (/ w qty))
    (setvar "osmode" 0)
      ); if mode Calc
    (if (= mode "Mnl")
        (if (= typ "X")
    (initget 1)
    (initget 1)
    (setq dist_X (getdist "\nEnter offset distance on X axis or click points: "))
    (setvar "osmode" 0)
(if (= typ "Y")
   (initget 1)
    (initget 1)
    (setq dist_Y (getdist "\nEnter offset distance on Y axis or click points: "))
    (setvar "osmode" 0)
(if (= typ "Grid")
    (initget 1)
    (initget 1)
    (initget 1)
    (initget 1)
    (setvar "osmode" 0)
      ); if mode Mnl
  ; evaluate object for inclination angle setting and set values
  (if (= hasangle "Yes")
      (setq ent   (car (entsel "\nSelect object to set inclination angle: "))
    (while (null ent)
(setq ent (car (entsel "\nPlease select an object: "))
  (setq en_data (entget ent)
en_type (cdr (assoc 0 en_data))
    ); hasangle
  (if (= en_type "LWPOLYLINE")
      (setq vert (cdr (assoc 90 en_data)))
(if (= vert 4)
    (setq en_type "T_1"
  pt1 (cdr (nth 14 en_data))
  pt2 (cdr (nth 18 en_data))
  ); for rectangle
      (if (= vert 3)
(setq en_type "T_1"
      (if (= vert 2)
(setq en_type "T_2")
      (if (> vert 4)
    ); if lwpolyline
  (if (= en_type "LINE")
  (if (= en_type "INSERT")
  (if (= en_type "TEXT")
  (if (= en_type "MTEXT")
;  Make array ;
  (if (= typ "X")
    (if (= hasangle "No")
      (command "-array" obj "" "_rectangular" "1" (fix qtx) dist_X)
    ); if no angle
(if (= en_type "T_1")
    (command "line" pt1 pt2 ""); draw line to set UCS Angle #find a variable to fix this#
    (setq tmp (entlast))
    (command "_ucs" "_object" tmp
     "_-array" obj "" "_rectangular" "1" (fix qtx) dist_X
     "_ucs" "_top"
     "_erase" tmp ""
); if "T_1"
(if (= en_type "T_2")
    (command "_ucs" "_object" ent
     "_ucs" "_top"
); if "T_2"
    ); if has angle
    ); X_array
  (if (= typ "Y")
      (command "_-array" obj "" "_rectangular" (fix qty) "1" dist_Y)
    ); if no angle
    (command "_line" pt1 pt2 "")
     "_ucs" "_top"
     "_erase" tmp ""
); if "T_1"
     "_ucs" "_top"
); if "T_2"
    ); if has angle
    ); Y_array
  (if (= typ "Grid")
      (command "_-array" obj "" "_rectangular" (fix qty) (fix qtx) dist_Y dist_X)
      ); if no angle
             "_ucs" "_top"
     "_erase" tmp ""
  ); if "T_1"
     "_ucs" "_top"
  ); if "T_2"
      ); if has angle
    ); Grid array
  ;(prompt "\nIf you want to undo the array use undo - <back> to return to mark ")
  (prin1)
); smart array
(prompt "\n smart_array is now available - type <SA> to start! ")
    **updated for international language support**
suggestions and tips welcome :)
cheers!
-rhino
« Last Edit: February 27, 2009, 11:06:29 AM by rhino »
Andrea
Re: smart array
« Reply #1 on: February 27, 2009, 10:50:34 AM »
First...Welcome to theswamp !
second...Thanks for sharing your code !
comments:
Not working...
maybe need to underscore all your command for language compatibilitie...
but knowing it is not easy to test when you have only 1 language version...
there we go.
  (setvar "osmode" 0)
  (setvar "angdir" 1)
    (princ
    (prin1)
;  Get User Input ;
  (setq obj   (ssget)
  (while (null obj)
      (setq obj (ssget)
    (if (= mode "Calc")
        (if (= typ "X")
   (initget 1)
   (initget 1)
dist_X (/ l qtx))
   (setvar "osmode" 0)
(if (= typ "Y")
   (initget 1)
   (initget 1)
dist_Y (/ w qty))
   (setvar "osmode" 0)
(if (= typ "Grid")
   (initget 1)
   (initget 1)
   (initget 1)
dist_X (/ l qtx))
   (initget 1)
dist_Y (/ w qty))
   (setvar "osmode" 0)
      ); if mode Calc
    (if (= mode "Mnl")
        (if (= typ "X")
   (initget 1)
   (initget 1)
   (setvar "osmode" 0)
(if (= typ "Y")
  (initget 1)
   (initget 1)
   (setvar "osmode" 0)
(if (= typ "Grid")
   (initget 1)
   (initget 1)
   (initget 1)
   (initget 1)
   (setvar "osmode" 0)
      ); if mode Mnl
   (while (null ent)
    ); hasangle
(if (= vert 4)
   (setq en_type "T_1"
); for rectangle
      (if (= vert 3)
(setq en_type "T_1"
      (if (= vert 2)
      (if (> vert 4)
    ); if lwpolyline
;  Make array ;
  (if (= typ "X")
      (command "._-array" obj "" "_rectangular" "1" (fix qtx) dist_X)
    ); if no angle
   (command "._line" pt1 pt2 ""); draw line to set UCS Angle #find a variable to fix this#
   (command "._ucs" "_object" tmp
    "._ucs" "_top"
    "._erase" tmp ""
); if "T_1"
   (command "._ucs" "_object" ent
    ".-array"  obj "" "_rectangular" "1" (fix qtx) dist_X
    "._ucs" "_top"
); if "T_2"
    ); if has angle
    ); X_array
  (if (= typ "Y")
      (command "._-array" obj "" "_rectangular" (fix qty) "1" dist_Y)
    ); if no angle
    "_ucs" "_top"
    "._erase" tmp ""
); if "T_1"
    "._ucs" "_top"
); if "T_2"
    ); if has angle
    ); Y_array
  (if (= typ "Grid")
      (command "._-array" obj "" "_rectangular" (fix qty) (fix qtx) dist_Y dist_X)
      ); if no angle
            "._ucs" "_top"
    "._erase" tmp ""
); if "T_1"
    "._ucs" "_top"
); if "T_2"
      ); if has angle
    ); Grid array
  (prin1)
); smart array
« Last Edit: February 27, 2009, 10:57:18 AM by Andrea »
Keep smile...
Re: smart array
« Reply #2 on: February 27, 2009, 04:34:08 PM »
Welcome to theSwamp.
I haven't looked at your code functionality , but you really should look at making the *error* function local to the routine.
--> Donate to theSwamp<--
rhino
Re: smart array
« Reply #3 on: March 02, 2009, 12:20:17 PM »
Andrea:
Hi and thanks - i guess we both edited at the same time but you were the quicker :)
Kerry:
I searched around the 'swamp' and found a post that  explained the whole error routine thing...so have updated the code
Questions & Help:
This routine arrays the objects on angles based on UCS - 'object' and 'points' for the closed polylines; however there seems to be a bug for the Y axis only option - is there a better way of setting the angle; other than asking the user to click points to set the angle?
I wonder if i used 'if' too much?
(defun c:smart_array (/ oldce oldosmd oldangd olderr obj mode typ hasangle qtx l
        dist_X dist_Y qty w ent en_typ vert lp1 lp2 pt1 pt2 tmp *error*)
  (setvar "osmode" 0)
  (setvar "angdir" 1)
    (princ
    (prin1)
;  Get User Input ;
  (setq obj   (ssget)
  (while (null obj)
      (setq obj (ssget)
    (if (= mode "Calc")
        (if (= typ "X")
    (initget 1)
    (initget 1)
  dist_X (/ l qtx))
    (setvar "osmode" 0)
(if (= typ "Y")
    (initget 1)
    (initget 1)
  dist_Y (/ w qty))
    (setvar "osmode" 0)
(if (= typ "Grid")
    (initget 1)
    (initget 1)
    (initget 1)
  dist_X (/ l qtx))
    (initget 1)
  dist_Y (/ w qty))
    (setvar "osmode" 0)
      ); if mode Calc
    (if (= mode "Mnl")
        (if (= typ "X")
    (initget 1)
    (initget 1)
    (setvar "osmode" 0)
(if (= typ "Y")
   (initget 1)
    (initget 1)
    (setvar "osmode" 0)
(if (= typ "Grid")
    (initget 1)
    (initget 1)
    (initget 1)
    (initget 1)
    (setvar "osmode" 0)
      ); if mode Mnl
    (while (null ent)
    ); hasangle
(if (= vert 4)
    (setq en_type "T_1"
  ); for rectangle
      (if (= vert 3)
(setq en_type "T_1"
      (if (= vert 2)
      (if (> vert 4)
    ); if lwpolyline
      (if (= typ "X")
(setq lp1 (cdr (assoc 10 en_data))
      lp2 (cdr (assoc 11 en_data))
      en_type (if (> (car lp1) (car lp2)) "T_1" "T_2")
(setq pt1 lp2
       pt2 lp1
); T_1
    ); typ "X"
;  Make array ;
  (if (= typ "X")
    ); if no angle
     "._ucs" "_top"
     "._erase" tmp ""
); if "T_1"
     "._ucs" "_top"
); if "T_2"
    ); if has angle
    ); X_array
  (if (= typ "Y")
    ); if no angle
     "._ucs" "_top"
     "._erase" tmp ""
); if "T_1"
     "._ucs" "_top"
); if "T_2"
    ); if has angle
    ); Y_array
  (if (= typ "Grid")
      ); if no angle
             "._ucs" "_top"
     "._erase" tmp ""
  ); if "T_1"
     "._ucs" "_top"
  ); if "T_2"
      ); if has angle
    ); Grid array
  (prin1)
); smart array
Re: smart array
« Reply #4 on: March 02, 2009, 12:45:55 PM »
Nice job.
Food for thought : http://www.theswamp.org/index.php?topic=7152.msg88168#msg88168
Welcome to TheSwamp.  :-)
gskelly
Re: smart array
« Reply #5 on: March 02, 2009, 07:46:26 PM »
I'm working on improving my LISP as well so take what I say with a
grain of salt (and check me against the help file)  :-)
Regarding the "if" question... you can use cond where you have a series
of options where only one is going to match. Similar to:
    ((= mode "Calc")
        ((= typ "X")
            (initget 1)
            (initget 1)
                  dist_X (/ l qtx))
            (setvar "osmode" 0)
        ((= typ "Y")
            (initget 1)
            (initget 1)
                  dist_Y (/ w qty))
            (setvar "osmode" 0)
        ((= typ "Grid")
            (initget 1)
            (initget 1)
            (initget 1)
                  dist_X (/ l qtx))
            (initget 1)
                  dist_Y (/ w qty))
            (setvar "osmode" 0)
    ); mode Calc
    ((= mode "Mnl")
        ((= typ "X")
            (initget 1)
            (initget 1)
            (setvar "osmode" 0)
        ((= typ "Y")
           (initget 1)
            (initget 1)
            (setvar "osmode" 0)
        ((= typ "Grid")
            (initget 1)
            (initget 1)
            (initget 1)
            (initget 1)
            (setvar "osmode" 0)
    ); mode Mnl
  ); end mode cond
You can also find a lot of examples around here where people use and to
continue executing statements until one returns nil as in:
(and
    (do_this)
    (do_that)
    (do_the_other_thing)
where each of do_this, do_that and do_the_other_thing will happen as long
as the preceding statement does not return NIL.
Note the and statement will return either T or NIL... not the result of the last
statement.
While I say this I will qualify with: I have not found it in my documentation
where execution is guaranteed to stop on the first NIL but it seems to work
for me. Perhaps someone with more knowledge than I can clarify if this is
the case and always was.
Have fun!
Bricscad v12
Re: smart array
« Reply #6 on: March 02, 2009, 08:35:21 PM »
rhino
Re: smart array
« Reply #7 on: March 03, 2009, 12:31:59 PM »
CAB:
Thanks for the links - food for thought hehe - really awesome stuff what can be done
I am looking for some more help/guidance on using the visual lisp functions though for now sticking to just the lisp.
gskelly:
Thanks for your input - i had tried the 'cond' function earlier but as I'm a novice did not figure out the correct way to use it :-o
I'll update the code over the weekend and also will work on making the routine remember the last user input when used
cheers!
gskelly
Re: smart array
« Reply #8 on: March 03, 2009, 10:04:14 PM »
Your welcome rhino...
Glad I could help someone a little... this place has helped much more than I can give back!
Bricscad v12
Re: smart array
« Reply #9 on: March 04, 2009, 12:29:45 AM »
rhino,
I took a few minutes and changed the user input section.
Too sleepy to continue, maybe tomorrow.
Didn't even test it, sorry.
          ;  Get User Input
  (while
    (and
      (princ "\nSelect objects to array.")
      (null(setq obj (ssget)))
  (or mode (setq mode "Calc"))
  (or typ (setq typ "X"))
  (initget "Yes No")
  (or hasangle (setq hasangle "No"))
  (if (member typ '("X" "Grid"))
      (initget 1)
      (initget 1)
      (setq l (getdist "\nDistance on X axis or click points: "))
      (if (= mode "Calc")
        (setq dist_X (/ l qtx))
      (setvar "osmode" 0)
  (if (member typ '("Y" "Grid"))
      (initget 1)
      (initget 1)
      (setq w (getdist "\nDistance on Y axis or click points: "))
      (if (= mode "Calc")
        (setq dist_Y (/ w qty))
      (setvar "osmode" 0)
