Author Topic: Misunderstanding rem function?  (Read 3172 times)
gskelly
« on: February 13, 2009, 07:49:32 PM »
Hi folks...
I've been lurking around here for a while... reading and learning. I am getting my feet under me so to speak but I am a bit confused with some results I am seeing when using the REM function.
Example: an angle in the format DD.MMSSsss converted to decimal degrees.
(defun g (dms / tmp)
    (setq tmp (rem dms 0.01))
        (fix dms)
        (/ (- (rem dms 1.0) tmp) 0.6)
        (/ tmp 0.36)
(g 1) gives 1.0 (good)
(g 31.01) gives 31.01666... (yeah!)
Now if I have a quadrant bearing in the format QDD.MMSSsss I figured I should be able to knock the quadrant Q off using REM:
(g (rem 131.01 100.0)) gives 31.02777... !!! this is not right !!!
this look to me like the (rem 131.01 100.0) must be returning 31.014, however,
(rtos (rem 131.01 100.0) 2 9) gives "31.01" which is what I expected.
Well, now I feel a bit dense. Am I doing something obvious wrong, like completely misusing REM?
Thanks.
Greg
Bricscad v12
Re: Misunderstanding rem function?
« Reply #1 on: February 13, 2009, 08:19:50 PM »
Long story short.
The implementation of REM is affected by the inherent inaccuracies of floating point calculations and the associated rounding anomalies.
« Last Edit: February 13, 2009, 08:33:39 PM by Kerry Brown »
gskelly
« Reply #3 on: February 13, 2009, 09:21:06 PM »
Long story short.
Ok... I had given that a passing thought but with the magnitude of the numbers I was dealing with I did not expect to see such significant roundoff errors due to floating point representation. I was also confused by the output from (rtos (rem 131.01 100.0) 2 9) yielding the expected "131.01"... Lesson learned.
Do you know if this high level of introduced error is limited to REM or should I be wary of other functions like angle and distance?
Thanks!
Bricscad v12
« Reply #4 on: February 13, 2009, 10:49:43 PM »
yes, I do know.
no, it's not limited to REM.
yes, be wary.
gskelly
« Reply #5 on: February 13, 2009, 11:13:04 PM »
Oops! I just found a recent post about REM I missed or forgot about...  :-(
Bricscad v12
gskelly
« Reply #6 on: February 14, 2009, 06:52:07 PM »
Well, I was just being a little dense last night... for whatever reason I was only using "9" for the precision in the rots calls I made  :ugly:
Need more sleep I guess...
Anyway it is very obvious with more precision displayed:
(g 31.01)
31.01
(rem dms 0.01) = 0.0000000000000009
     (fix dms) = 31
 (rem dms 1.0) = 0.0100000000000016
31.01666666666667
(g (rem 131.01 1.0))
31.00999999999999
(rem dms 0.01) = 0.0099999999999903
     (fix dms) = 31
 (rem dms 1.0) = 0.0099999999999909
31.02777777777775
Thanks Kerry.
Bricscad v12
vladimirzm
« Reply #7 on: February 16, 2009, 05:18:48 PM »
i don't know but for me it doesn't sound like a "precision" problem:
(rtos (- 200 0.1) 2 20)  ---> "199.9"
(rtos (- 1000 0.1) 2 20) ---> "999.9"
but
(- 100 0.1)  ---> 99.9 ok?
(rtos (- 100 0.1) 2 20) ---> "99.90000000000001"
so the problem is not REM itself. try to build a new version of REM and you will find the same problem.
gskelly
« Reply #8 on: February 16, 2009, 07:31:37 PM »
Yes, you are correct, I was misusing the function and not alert enough to realize it.
Thanks.
Bricscad v12
