Author Topic: DHline v.1.0 !! ;-)  (Read 9032 times)
Andrea
DHline v.1.0 !! ;-)
« on: January 26, 2009, 03:37:35 PM »
tired to trim and cut or erase some line....!!??
there it is..
D H L I N E
Dynamic Hidden Line v.1.0
You can now draw any line without specifying level.
DHLINE auto-detect the entity made on same layer. but you can
filter entity as your need.
Use Shift Key to switch the hidden Line steps.
ENJOY !   :roll:
Keep smile...
DEVITG
Re: DHline v.1.0 !! ;-)
« Reply #1 on: January 26, 2009, 07:05:42 PM »
Hi Andrea , I do a burning test to the DHLINE , I got some error .
I made it all in one command
And I can not end drawing line , I had to ESCAPE.
See attached the dwg and the text screen shoot
Andrea
« Reply #2 on: January 26, 2009, 11:21:17 PM »
well....you'r right...
sorry..
it seem that it don't like closed entity.. :|
let me see if i can do something...
 :pissed:
Keep smile...
DEVITG
« Reply #3 on: January 27, 2009, 03:06:26 AM »
Hi Andrea , I did  it so because it was the easiest way , to draw a rectangle .
I  try it with open poly,   lines, circle, and still send a error message when want to exit , it can be only do by Esc.
It make the hidden lines good.
« Last Edit: January 27, 2009, 03:13:39 AM by DEVITG »
GDF
« Reply #4 on: January 27, 2009, 09:51:40 AM »
Pretty slick...keep up the good work and thanks for sharing.
Andrea
« Reply #5 on: January 27, 2009, 12:35:34 PM »
ok....
I have found 2 min. to fix that...yeah ! :evil:
it is now fixed. !
D H L I N E
Dynamic Hidden Line v.1.1
but....I've found strange reaction for closed Polyline..
(see animated GIF below)
don't know realy why... :|
if someone can explain that..i'm curious to know..
Thanks again !
Keep smile...
« Reply #6 on: January 27, 2009, 12:54:21 PM »
Maybe try sorting your intersection points from the distance closest to the picked point?
*after actually trying the routine I get this:  Application ERROR: Invalid type sent as command input
and cannot exit without using ESC....and does not draw in dashed lines.
« Last Edit: January 27, 2009, 12:58:45 PM by ronjonp »
Andrea
« Reply #7 on: January 27, 2009, 02:27:31 PM »
that what i did.. :?
the code work with "ACAD_ISO03W100" linetype..
not autoloaded...
I've add this code to load it as default..(see version 1.2)
but you can change for your need...
(if (eq (getvar "measurement") 0)
  (setq Linf (findfile "acad.lin"))
  (setq Linf (findfile "acadiso.lin"))
(if Linf
(if (not (member "ACAD_ISO03W100" (mapcar 'strcase (ai_table "LTYPE" 4))))
  (vl-cmdf "._Linetype" "_L" "ACAD_ISO03W100" Linf "")
Keep smile...
Andrea
« Reply #8 on: January 27, 2009, 09:18:37 PM »
There it is.....
D H L I N E
Dynamic Hidden Line v.1.3
some FIX:
- RightClick allow to stop the routine.
- Cancel improved
- Some Variables verifications
I've made many tests before posting..
Please let me know if it work !
thanks.
Keep smile...
« Reply #9 on: January 27, 2009, 10:32:44 PM »
There it is.....
D H L I N E
Excellent!  :roll:
