Author Topic: Quit civil 3d 2009 session without saving  (Read 5074 times)
sonayd
« on: January 26, 2009, 01:21:26 PM »
anyone experience thisssss :lol:
im doing a cut and paste on a dwg and close.  soon i click close (and traditionally will ask me to save it or not), it did not prompt me any question  :ugly:.  I did recheck the file and all the entities that i cut was gone.
Re: Quit civil 3d 2009 session without saving
« Reply #1 on: January 26, 2009, 01:30:01 PM »
If you are really trying to copy and paste C3D entities like that you are going to have No Fun.
You will be best served to
A) Export the data via XML, import into the desired file and apply styles as required
OR
B) Issue data shortcuts for that data
Reference it in to the destination file and apply styles as required
OR
C)  Crash C3D into a wall. (here's your helmet)
sonayd
« Reply #2 on: January 26, 2009, 07:40:51 PM »
What I'm cutting and pasting was just dumb entities.  i also tried draw lines, circles, create-delete viewports, insert anything on a brand new file... when you close (without saving) will not prompt me any choices of saving it or not.  And the worst thing is that only happening on my computer that's 1 of 7 workstation running c3d2009.
« Reply #3 on: January 26, 2009, 08:20:57 PM »
OK, do you have the open close save hot fix applied to all machines?
Or did yours get skipped when they were applying patches to C3D?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11783277&linkID=11705366
« Last Edit: January 26, 2009, 08:26:50 PM by mjfarrell »
sonayd
« Reply #4 on: January 27, 2009, 01:15:57 PM »
I did checked the version and I have the latest sp (update 2).  the strange thing is that why is not asking me to save it or not.  cvl3d just automatically saving it.
Im thinking of reinstalling the cvl3d again. :realmad:
I even uninstall all my lisp routine...... no luck, problem still there.
« Last Edit: January 27, 2009, 01:27:17 PM by sonayd »
« Reply #5 on: January 27, 2009, 02:05:51 PM »
Out of curiosity, what is your EXPERT sysvar set to?
sonayd
« Reply #6 on: January 27, 2009, 03:09:06 PM »
currently on 0.  i changed to 1,2,3,4, and 5, (tried filedia too) none work.  still not prompting me to save it or not. :cry:
« Reply #7 on: January 27, 2009, 03:39:08 PM »
Yeah, I didn't think it would affect it, but thought it was worth a try.
One last idea I have, do you have a third party application running that autsaves your drawings at a set time, thereby resetting the drawing's internal "needs to be saved" variable (DBMOD)?
sonayd
« Reply #8 on: January 27, 2009, 03:45:32 PM »
none.... no 3rd party softwares running. (thanks)
anyone out there experiencing this problem??????? please help  :cry: before i decided to reinstall cvl3d :cry:
« Reply #9 on: January 27, 2009, 03:50:35 PM »
try exporting the profile from a machine that IS working correctly
import and set current on the offending machine and test....
If FAIL
Happy removing the software Day to You!
sonayd
« Reply #10 on: February 03, 2009, 12:55:00 PM »
Hey Jeff_M,  you're right i do have 3rd party software running (did not notice) called "DWGMAN" (http://www.caelink.com/).   ive checked the option and 1 of the option is to "ALWAYS SAVE".
TO ALL:
Thanks for all the input. :angel:
[/size]
Problem Solved
« Last Edit: February 03, 2009, 01:00:53 PM by sonayd »
« Reply #11 on: February 03, 2009, 03:15:43 PM »
I'm glad we could help you find the solution! And thanks for letting us know what that solution was.
