Author Topic: Material Takeoff Routine Needed.  (Read 14074 times)
JCUTRONA
Re: Material Takeoff Routine Needed.
« Reply #45 on: January 30, 2009, 10:08:50 AM »
"midpoints < 6 units apart"<<<< This is brilliant.  Wouldn't have thought of that for years, and if I had, would not been able to write it for more years.  I am impressed sir.
LISP (Lost in Stupid Parentheses)
« Reply #46 on: January 30, 2009, 10:09:35 AM »
We give newbies extra latitude. :)
Usually we teach LISP so you can create and fix your own routine but this one is too complex for
a first time lisper for sure.
AS for learning LISP it is usualy a steap learning curve if you have never programed before but only
moderate if you have background. I would say 3 month to a year before you are walking with LISP.:)
It all depends on your staring level & the amount of time you apply to study & practice.
To get off the ground in a hurry you should read from these sites:
Start at the beginning   http://www.afralisp.net/
http://jefferypsanders.com/autolisp.html
http://ronleigh.info/autolisp/index.htm
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=770225
Intermediate to Advanced:
http://pages.cs.wisc.edu/~vernon/cs367/notes/6.RECURSION.html
Advanced:
http://www.atablex.com/htmls/excel-bible.htm
http://www.steinvb.net/vldb/
http://www.caddigest.com/subjects/autocad/tutorials/select/parsai_vlx.htm
References:
http://www.hyperpics.com/commands/index.asp
http://www.autodesk.com/techpubs/autocad/acad2000/dxf/
Extra credit:
http://www.analogx.com/contents/articles/howtoprg.htm
http://www.paulgraham.com/progbot.html
http://www.dreamsongs.com/SeatBelts.html
http://www.dreamsongs.com/ArtOfLisp.html
That's all I have time for this morning.
My advice, start small & let you routine grow with your abilities.
There is plenty of help here at TheSwamp just for the asking? :)
« Last Edit: January 30, 2009, 10:17:14 AM by CAB »
« Reply #47 on: January 30, 2009, 10:12:07 AM »
Thanks you Sir.
Not infallible but given that we are dealing with specific layers I opted not to test for parallel lines
which would be a safety feature.  8-)
JCUTRONA
« Reply #48 on: January 31, 2009, 04:44:02 PM »
The Jeff Sanders stuff is VERY easily understood.  Even for a first timer...  Progressing now.
« Reply #49 on: January 31, 2009, 06:38:11 PM »
That's a pretty good reading list Alan.
« Reply #50 on: January 31, 2009, 09:00:06 PM »
Thanks Kerry.
It will keep most beginners busy for quite some time. 8-)
« Reply #51 on: February 02, 2009, 12:45:14 AM »
I found these links too but have not explored them.
Link to pdf Lessons:
http://forums.augi.com/showpost.php?p=190406&postcount=21
14 lessons by Dave Pitzer
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=2309147
follow the link at the bottom of each lesson
Free AutoLisp course
http://forums.augi.com/attachment.php?attachmentid=3425&d=1093637254
