Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
(Microstation) Draw Order
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: (Microstation) Draw Order (Read 7339 times)
wannabe
Guest
on:
January 13, 2009, 08:58:32 AM »
Anyone able to enlighten me on the Microstation alternative to this acad feature, please?
Logged
Seagull
Every Student their own Lesson
WWW
Re: Draw Order
Reply #1 on:
January 13, 2009, 11:01:39 AM »
Display Priority
(2D models only) Identifies the level display priority value. A level with the highest priority value displays in front, while a level with the lowest priority value displays in back. Reference and element priority values also affect the display.
Key-in: level set priority <new-level-priority [file:file-spec] level-spec>
from this Great Resource
http://docs.bentley.com/en/MicroStation/ustnhelp89.html#nowhere
Logged
wannabe
Guest
Re: Draw Order
Reply #2 on:
January 13, 2009, 01:04:31 PM »
I have been told v8 2004 has no draw order due to on-screen entity population being in order of creation. Bit of a joke, but the new versions seem to be updated accordingly.
Logged
PHX cadie
Water Moccasin
Re: Draw Order
Reply #3 on:
January 13, 2009, 02:31:13 PM »
for setting references as a whole we have been told to use Settings>Update Sequence, from the Reference box. The last in the list has the higher priority.
(Hope I'm not off base with this one)
Logged
Acad 2013 and XM
skennedy
Guest
Re: Draw Order
Reply #4 on:
January 20, 2009, 09:09:32 AM »
there is also the command:
order element front
Logged
wannabe
Guest
Re: Draw Order
Reply #5 on:
January 20, 2009, 06:01:36 PM »
on V8 2004 it doesn't really do the trick. Not after you mouse over another coincidental element.
V8i has thankfully improved upon this.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
