Author Topic: Layer filter wildcards  (Read 5265 times)
EagerToLearnCad
« on: December 22, 2008, 01:39:46 PM »
For layer filters, if I just want the main layers names (excluding xref layer name)
in a drawing I use the wilcard "~*|*".
What woud the wildcard be if I want only layers that begin with letter "M"
(m for mechanical) & excluding all xref layers?....Thanks in advance.
Krushert
  • FREE BEER Tomorrow!!
Re: Layer filter wildcards
« Reply #1 on: December 22, 2008, 01:55:23 PM »
Interesting
Let me go look up something of Mark's
Krushert
« Reply #2 on: December 22, 2008, 02:26:45 PM »
This is interesting.  looks like you an only filter for either or the first time.  It seems you can not filter a already filter list.
Somebody a lot smarter that me might think of a way around this.
In the meantime, you might want to take a look at Mark's Using wildcards to find things.  Very helpful for me so far.  until now
« Reply #3 on: December 23, 2008, 06:59:02 AM »
I think this is the filter you want
[M][~*|*]*
Anything starting with 'M' followed by anything except containing '|'
« Reply #4 on: December 23, 2008, 07:43:21 AM »
well that doesn't work but this will.
(setq ss (ssget '((8 . "M*") (8 . "~*|*"))))
EagerToLearnCad
« Reply #5 on: December 23, 2008, 08:38:43 AM »
Cab,
It did'nt work. Thank you for trying.
« Reply #6 on: December 23, 2008, 09:52:19 AM »
That should work to create a selection set.
What exactly are you trying to do with the layer names?
Krushert
« Reply #7 on: December 23, 2008, 10:01:12 AM »
Here is is a routine from MP that I use a lot to create the filter out xrefs layers.
It is worth sharing both from it value in what it does and the hope of you might be able to mine something from the code.
« Reply #8 on: December 23, 2008, 10:15:22 AM »
If you're trying to create a layer filter AND you're not interested in doing it thru code one way you could achieve the above is to use a filter that matches the opposite of what you want and invert it. I don't have a lot of experience creating them manually but I believe you need to create 2 entries for the filter above, one would be ~M* and the other would be *|*.
Inverted it yields "All layers that start with M that are not xref based".
Edit: Added piccy:
« Last Edit: December 23, 2008, 10:30:36 AM by MP »
Krushert
« Reply #9 on: December 23, 2008, 10:34:04 AM »
Sweeeeeettttt  :-)
EagerToLearnCad
« Reply #10 on: December 23, 2008, 11:22:29 AM »
MP,
Thank you!..By the way, What did you mean  "Edit: Added piccy:"?
Krushert,
Thank you too!..You saved me time. This was the next thing I was going
to research.
Happy Holidays Everyone!!!
Krushert
« Reply #11 on: December 23, 2008, 11:25:04 AM »
MP,
Krushert,
to research.
No problem and Welcome to The Swamp
MP had come back and added the image of the screen shot
EagerToLearnCad
« Reply #12 on: December 23, 2008, 12:21:24 PM »
Krushert,
Me again. From the coding examples, I'm able to create "~M*".
But not the second  line "*|*". Do you know how?
« Reply #13 on: December 23, 2008, 12:38:17 PM »
Krushert,
Separate the filters with a comma. (1 . "m*,*|*")
« Reply #14 on: December 23, 2008, 12:47:12 PM »
Note the the comma is an implied OR.
