Author Topic: scales  (Read 1458 times)
AUTOKAD
scales
« on: October 16, 2008, 02:44:51 PM »
Hello
why are there so many scales? (see attached). how to get rid of this. Please help thanks
Re: scales
« Reply #1 on: October 16, 2008, 02:53:07 PM »
jonesy
  • SuperMod
Re: scales
« Reply #2 on: October 16, 2008, 02:53:18 PM »
you need to reset the scalelist. Theres a lisp floating around theswamp, but I think theres also a native autoCAD command that resets the scalelist. (Scalelistedit I think does the trick)
Gliderider
Re: scales
« Reply #3 on: October 16, 2008, 03:04:42 PM »
-scalelistedit > reset
if you have too many scales it may not work so you may want to look at this...
http://autodesk.blogs.com/between_the_lines/2008/04/scale-list-clea.html
Krushert
  • FREE BEER Tomorrow!!
Re: scales
« Reply #4 on: October 16, 2008, 04:19:33 PM »
even with the sevice patch installed I will still get them but I delete them upon opening of drawing files
add this to your start up.
(command "-scalelistedit" "R" "Y" "E" ) ; DELETES MEMORY SUCKING XREF SCALELIST
(command "-purge" "R" "*" "n"); Purges all annoying RegApps
