Author Topic: wcmatch problem  (Read 1470 times)
hmspe
wcmatch problem
« on: October 16, 2008, 12:28:04 PM »
I'm probably missing something obvious.  I've used WCMATCH many times in the past, but today it's not cooperating.  I've added the following for debugging
(print i_type)
(print (wcmatch i_type "S"))
I'm getting this returned
"SLL"
nil
This is in R2004.  I've worked around by using vl-string-position, but I'd like to know what I'm missing here.
Martin
"Science is the belief in the ignorance of experts." - Richard Feynman
Re: wcmatch problem
« Reply #1 on: October 16, 2008, 12:31:24 PM »
That is testing is the variable i_type = S.  If you want to know if it starts with S, then use
(print (wcmatch i_type "S*"))
Command: (wcmatch "S" "S")
T
Command: (wcmatch "SILL" "S")
nil
Command: (wcmatch "SILL" "S*")
T
hmspe
Re: wcmatch problem
« Reply #2 on: October 16, 2008, 01:27:44 PM »
Thanks.
