Author Topic: How to list all subentitys of a block?  (Read 3347 times)
taner
« on: October 13, 2008, 10:05:39 PM »
Dear all,
How to list all subentitys of a block? thanks!
taner
Re: How to list all subentitys of a block?
« Reply #1 on: October 13, 2008, 10:14:39 PM »
What sort of list ?
What information do you want ?
taner
« Reply #2 on: October 13, 2008, 10:28:24 PM »
What sort of list ?
ename of subentity without sequence
« Reply #3 on: October 13, 2008, 10:37:11 PM »
« Reply #4 on: October 14, 2008, 05:25:54 AM »
taner, just for interest, what do you propose doing with the entity list when you have it. I'd like to make you aware that the entitys do not reside in the block reference, but in the block definition in the block table. I haven't had a good look at the code Alan referenced, but I'm sure you'll see from that what I mean.
taner
« Reply #5 on: October 14, 2008, 06:03:29 AM »
when i get the ename list of the subentitys,I can change some kinds of type(such as line,circle)entity's color ,layer etc.
thanks.
taner
« Reply #6 on: October 21, 2008, 08:14:06 PM »
I solved it finally.
(defun th-subelst-blk (blkname / blk lst)
  (setq blk (vla-item (vla-get-blocks (vla-get-activedocument
                           (vlax-get-acad-object)
            ) blkname
  (vlax-for each blk (if (/= (vla-get-objectname each) "AcDbBlockReference")
             (setq lst (cons each lst))
             (setq lst (append
               (th-subelst-blk (vla-get-name each))
               lst
  lst
« Reply #7 on: October 21, 2008, 11:09:10 PM »
That works pretty well....but you still have to account for attributes. :-)
*edit From my tests this morning, it grabs attributes too....I'll just shut up now :ugly:. Good Job!
« Last Edit: October 22, 2008, 08:55:26 AM by ronjonp »
« Reply #8 on: October 22, 2008, 11:00:47 AM »
Depends what attributes you are talking about.  This will grab the attribute definition, not the attribute reference, so if you want to change the existing attributes of the inserts already inserted, then this way will not work.  But if you don't, then it will.
