Author Topic: Text problems  (Read 1599 times)
jonesy
  • SuperMod
Text problems
« on: October 13, 2008, 06:12:03 AM »
I'm in the process of standards checking some drawings and I've come across a problem with some text in tables dimensions and dtext looking bold in some cases, but not in others.
What could be causing this? I have checked the Z and on each case the Z height is 0.
Many thanks in advance
T :)
New Shooz
Re: Text problems
« Reply #1 on: October 13, 2008, 06:30:50 AM »
how far away is your text from 0,0 ?
jonesy
  • SuperMod
Re: Text problems
« Reply #2 on: October 13, 2008, 06:42:10 AM »
text is less than 10000 units from 0,0.
Some text in tables and has the same problem too.
(I meant to add this image to the first post so theres a visual of whats happening)
New Shooz
Re: Text problems
« Reply #3 on: October 13, 2008, 06:49:29 AM »
try changing the z value of all the text to some arbitrary figure, say 9999; then change it all back to 0 ?
jonesy
  • SuperMod
Re: Text problems
« Reply #4 on: October 13, 2008, 08:26:31 AM »
Thanks Chortle, that worked for MOST of the text. I just had to redo some of the vertical dims, and job done.
Cheers
T :)
jonesy
  • SuperMod
Re: Text problems
« Reply #5 on: October 27, 2008, 07:46:07 AM »
OK, I'm having more problems with text that wont look right.
I've tried and tried the moving into a +z and a -z and then back to z of 0 and I cant get it to change. So the next thing I tried is stripping the mtext (as it had been over-ridden, but I cant seem to get all the formats stripped out of the mtext. Does anyone know what the "code" pxqc is in mtext? See image below...  Or am I going completely mad, and that means nothing, and wont effect anything.
Many thanks AGAIN!
T :-)
New Shooz
Re: Text problems
« Reply #6 on: October 27, 2008, 08:45:08 AM »
this post on AUGI may be of some use
Text Justifications in Mtext
jonesy
  • SuperMod
Re: Text problems
« Reply #7 on: October 27, 2008, 08:51:08 AM »
Thanks Chortle Again !!!
