Author Topic: BOM Utility to extract selective attributes from blocks with tabulation  (Read 18941 times)
Arthur Gan
Re: BOM Utility to extract selective attributes from blocks with tabulation
« Reply #45 on: October 17, 2008, 01:03:43 PM »
this code still does not work, can you help to make it work?
Try this version.
It was finding the file but there was a bug in the DCL syntax.
Arthur Gan
« Reply #46 on: October 17, 2008, 01:10:33 PM »
i tried this edited version from cab?
is this originally coded by you?
would appreciate if can you help to make it run?
You guys are fast, I’m still working on mine
The same with me :)
~'J'~
It's Alive!
  • Retired
  • AKA Daniel
« Reply #47 on: October 20, 2008, 03:35:02 PM »
Getting Close
It's Alive!
  • Retired
  • AKA Daniel
« Reply #48 on: October 20, 2008, 10:58:25 PM »
Give this a try, there is still lots of work to do as you will see.
The command it A2T
Oh yea .. you will need .NET 2.0 or better to run this
« Last Edit: October 20, 2008, 11:59:25 PM by Daniel »
Arthur Gan
« Reply #49 on: October 21, 2008, 12:29:10 AM »
Excellent beta! the program logic is correct but the table labels need to be corrected ie.
Block Table should be name of Block or one of the defined attribute tag eg. Door, Windows or Toilet so if Toilet there should be an attribute tag named Group such that wash basin, urinals, water closets can be grouped into one table named Toilets
There should also be header labels for Model Number, Tradename, Product and Material
It's Alive!
  • Retired
  • AKA Daniel
« Reply #50 on: October 21, 2008, 12:39:16 AM »
I also need to tally up the duplicate blocks and provide a quantity column. There seems to be something weird going on with the row height, it doesn’t want to stick in certain instances.
Strange how the background on the form is black, I thought I hard coded it to be white..hmmm
Dan
