Author Topic: OSNAP NOT WORKING ON SOME OBJECTS  (Read 2600 times)
STEVEDALLAS
« on: August 26, 2008, 11:56:46 AM »
I am inserting a block in Autocad 2009.
When I select it, The grips appear and I can do stuff with it.
When I want to put something on it, like a leader or line (for example), The osnaps will not lock onto a postion on that block.
ideas? suggestions?
Re: OSNAP NOT WORKING ON SOME OBJECTS
« Reply #1 on: August 26, 2008, 12:09:52 PM »
ideas? suggestions?
let me see that Bad Block object....
STEVEDALLAS
« Reply #2 on: August 26, 2008, 12:24:29 PM »
Here it is.
Try to snap to one of the corners.
It looks like "span to insertion point" is the only one that seems to work on mine.
Like I said, I am using 2009.
The block is saved in 2004, I think.
Hmmmm, I have an idea.
SDETERS
« Reply #3 on: August 26, 2008, 12:29:55 PM »
The Snaps work in 2007 ok
« Reply #4 on: August 26, 2008, 12:31:37 PM »
check your settings as shown in attached
« Reply #5 on: August 26, 2008, 12:35:11 PM »
I'm pretty sure that it has to do with that file being a nested unnamed block, autocad hates those.
Which is why it works when opened directly, however not when attached as an XREF.
