Author Topic: VLA-GET-MATERIALS how to incluse this missing componet in autocad 2005 for lisp  (Read 4504 times)
shamsam1
this two methods are missing in autocad2005. Is there any website where
we can download are any steps to include this two component
to check if VLA-GET-MATERIALS is there in autocad Steps to follow
Step 1: Command: (vl-load-com)
Step 2: Command: (vlax-dump-object(vla-get-ActiveDocument(vlax-get-acad-object))t)
Materials (RO) = #<VLA-OBJECT IAcadMaterials 0fa4f884>
ActiveMaterial = #<VLA-OBJECT IAcadMaterial 0fa362b4>
« Last Edit: August 06, 2008, 08:09:48 AM by shamsam1 »
jbuzbee
just a guess:
(vlax-get acadobject 'materials)
(vlax-get acadobject 'activematerial
James Buzbee
Windows 8
shamsam1
wel still its gives the error in lisp program
this is smple program which i am using to attach material to layer.it work fine in autocad 2007 but in 2005 its shows error : no function definition: VLA-GET-MATERIALS
(defun c:pumat(/ Lst sSet mLst cMat sCnt lCnt mCnt eCnt)
  (setq Lst (list
          '("0" "Global")
'("Layer1" "material1")
        ); end list
            ); end setq
(if(setq sSet(ssget "_X" '((0 . "*SOLID"))))
    (setq sCnt 0 lCnt 0)
    (vlax-for mat (vla-get-Materials
           (vlax-get-acad-object)))
      (setq mLst(cons(vla-get-Name mat)mLst))
      ); end vlax-for
    (foreach itm
        (mapcar 'vlax-ename->vla-object
          (vl-remove-if 'listp
            (mapcar 'cadr(ssnamex sSet))))
         (if(setq cMat
         (cadr
           (assoc
             (setq cLay(vla-get-Layer itm))Lst)))
      (if(member cMat mLst)
        (if(vl-catch-all-error-p
             (vl-catch-all-apply 'vla-put-Material
          (list itm cMat)))
          (setq lCnt(1+ lCnt))
          (setq sCnt(1+ sCnt))
          ); end if
        (if(not(member cMat mCnt))
         (setq mCnt(cons cMat mCnt))
          ); end if
        ); end if
      (if(not(member cLay eCnt))
        (setq eCnt(cons cLay eCnt))
        ); end if
          );end if
       ); end foreach
    (if(or(/= 0 lCnt)(/= 0(length mCnt))(/= 0(length eCnt)))
   (princ "\n========================= ERROR LIST =========================\n")
   (if(/= 0(length mCnt))
       (princ "\nFollowing materials missed in drawing: \n")
       (foreach mat mCnt
         (princ(strcat "\n " mat))
         ); end foreach
       (princ "\n")
       ); end progn
     ); end if
       (if(/= 0(length eCnt))
       (princ "\nSome solid layers missed in list: \n")
       (foreach lay eCnt
         (princ(strcat "\n " lay))
         ); end foreach
       (princ "\n")
       ); end progn
     ); end if
    (if(/= 0 lCnt)
      (princ(strcat "\n" (itoa lCnt) " were on locked layer!\n"))
     ); end if
   (princ "\n========================== END LIST ==========================\n")
   (textscr)
   ); end progn
      ); end if
         (princ(strcat "\n<<< Materials are appropriated for "
            (itoa sCnt) " of "
            (itoa(sslength sSet)) " solids >>>"))
    ); end progn
  (princ "\n<!> No Solids Found <!> ")
  ); end if
  ); end of c:pumat
shamsam1
Still problem not solved :-( for autcad2005
