Author Topic: (C3D) X-sections and surface  (Read 2170 times)
  • Custom Title
« on: July 25, 2008, 01:34:17 PM »
If you create a surface then x-sections of that surface does the surface update if you edit the surface lines in the sections?
sinc
Re: (C3D) X-sections and surface
« Reply #1 on: July 25, 2008, 02:02:08 PM »
How would it determine the correct modification to your model that would create the change you want in the section?
Editing corridor x-sections is a different story, because editing the x-section alters the corridor definition for that station.  Then the corridor surface is generated from the corridor definition.
But when we start talking about sample lines across surfaces, there are an infinite number of changes that could be applied to the surface definition in order to create the desired change along the sample line.
« Reply #2 on: July 25, 2008, 02:40:25 PM »
No, however if one uses the View Edit sections tool as sinc indicated one may override any sub assembly value at that station or for a range of stations.  Although there is a weird feature in that tool as well. If one goes to say Sta 12+50 and actually draws a Smiley Face in the section, then the smiley face will plot in your section views.  Weird, but interesting.
dfarris75
« Reply #3 on: July 25, 2008, 02:51:22 PM »
Always good to keep your surfaces happy! :-D
