Hi folks,
It's me and my zombie thread again. ![cheesy :lol:](http://www.theswamp.org/Smileys/black/cheesy.gif)
Hi Alex,
can't help you there(1) - anyway, was your January visualization by any chance from http://www.graphviz.org ? I've found that with saveas in SVG format and (mis-)using Visio to convert the output to an acceptable DWG it's a pretty cool tool.
(1)Your static GetBlockReferenceIds replacement method seems pretty innocent, are you sure that you are always avoiding the pitfalls of BlockTableRecord.GetBlockReferenceIds? I.e. it may return ObjectIds where IsEffectivelyErased == true, or calling it with directonly != true so that parent objects of nested blocks are included?
![huh :?](http://www.theswamp.org/Smileys/black/huh.gif)
It seems the problem stems from my having AutoCAD Mechanical installed. If I run the code from within VS, it automatically starts AutoCAD Mechanical - which means the code fails.
If I run the code from regular AutoCAD, i.e. not within the Dev. environment, it runs as designed.
Does anybody know how to force AutoCAD to start normally without the Mechanical crap - I talked to Kean Walmsley about it and he said to copy the command-line switches from the AutoCAD shortcut to the Debug page, but when I look at the shortcut for AutoCAD there are none, yet the Mechanical shortcut has " /p <<ACADMPP>>"
EDIT: Perhaps I could just use "/p"?? You can indeed use "/p" in the Command Line Arguments box on the Debug page.
And yes, the visualization was from Graphviz - it's pretty cool.
