Author Topic: Project-Auditing dwgs to a CAD Standard  (Read 34576 times)
Glenn R
Re: Project-Auditing dwgs to a CAD Standard
« Reply #45 on: July 22, 2008, 04:46:09 PM »
I know in theory we are opening them thru ObjectDBX ( i think) and somehow storing the values we want to check against.  Layers for instance, we would create an array maybe, and check layer names against that?  Or is there a better way?
Yes. We load the dwg file into memory and whenever we want to do something against it, we just start a transaction op against and do our thing. No need to store layers in an array and we already would be storing the whole drawing file itself, which has ALL we need.
Also, are there more plugins to the DWS than Layers, Dims, linetypes and textstyles
To date, I've never seen any and it's a pity. I think this is very powerfull and very much under-utilised. I have actually asked Kean to make a post of this and he's responded saying it's a great idea and he'll get to it 'in the coming weeks'.
Until then, we keep on keeping on.
« Reply #46 on: July 22, 2008, 05:24:59 PM »
Here is one way to get all objects to "ByLayer" color, linetype and lineweight.  If not a good way let me know so I can learn also.   :-)
public void ChangeAllToByLayer( Database db ) {
    const short cColor = 256;
    const LineWeight cLw = LineWeight.ByLayer;
    const string cLtStr = "ByLayer";
    Entity Ent;
    using ( Transaction Trans = db.TransactionManager.StartTransaction() ) {
        BlockTable BlkTbl = Trans.GetObject( db.BlockTableId, OpenMode.ForRead ) as BlockTable;
        LinetypeTable LtTbl = Trans.GetObject( db.LinetypeTableId, OpenMode.ForRead ) as LinetypeTable;
        ObjectId LtId = LtTbl["ByLayer"];
        foreach ( ObjectId btrId in BlkTbl ) {
            BlockTableRecord btr = Trans.GetObject( btrId, OpenMode.ForRead ) as BlockTableRecord;
            if ( !btr.IsFromExternalReference ) {
                foreach ( ObjectId objId in btr ) {
                    Ent = Trans.GetObject( objId, OpenMode.ForWrite ) as Entity;
                    Ent.ColorIndex = cColor;
                    Ent.Linetype = cLtStr;
                    Ent.LinetypeId = LtId;
                    Ent.LineWeight = cLw;
                    if ( Ent is BlockReference ) {
                        BlockReference BlkRef = Ent as BlockReference;
                        AttributeCollection AttCol = BlkRef.AttributeCollection as AttributeCollection;
                        foreach ( ObjectId attId in AttCol ) {
                            Ent = Trans.GetObject( attId, OpenMode.ForWrite ) as Entity;
        Trans.Commit();
David Hall
  • Automatic Duh Generator
« Reply #47 on: July 22, 2008, 06:06:29 PM »
Question about the reporting piece of this excercise.  Are we wanting to fix it or report it.  TW, I am definetly going to copy that as it looks really good to me, however, are we wanting to fix the problem or report it to the insultants?  And if we report it, is their a way to flag the instance of the problem.  I'm thinking about the way Autocad Map flags problems
« Reply #48 on: July 22, 2008, 06:23:05 PM »
I guess if we wanted to report it, we can do it the way audit does.  If gives the handle, and the dxf name, then we can say what part of it is out of order; color, linetype or lineweight.
David Hall
« Reply #49 on: July 22, 2008, 06:30:03 PM »
Having never used ObjectDBX, you can see where I thought that was the correct terminology.  After you have explained that better, I now see why I was incorrect in using it.  Cool, moving on.
David Hall
« Reply #50 on: July 22, 2008, 06:30:50 PM »
TW, I think we should code it both ways
« Reply #51 on: July 22, 2008, 06:44:58 PM »
Almost there.
« Reply #52 on: July 22, 2008, 06:54:16 PM »
Almost there.
Here is a working copy of a reporting version.
public void ReportNonByLayer( Database db ) {
    Entity Ent;
    Editor Ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
    StringBuilder sb;
    bool HasErrors;
    RXClass rxc;
                    Ent = Trans.GetObject( objId, OpenMode.ForRead ) as Entity;
                    rxc = Ent.GetRXClass();
                    sb = new StringBuilder( rxc.DxfName + "(" + Ent.Handle + ")" );
                    HasErrors = false;
                    if ( Ent.ColorIndex != cColor ) {
                        sb.Append( "    Color" );
                        HasErrors = true;
                    if ( Ent.Linetype != cLtStr || Ent.LinetypeId != LtId) {
                        if ( HasErrors )
                            sb.Append( " / Linetype" );
                        else
                            sb.Append("    Linetype");
                        HasErrors = true;
                    if ( Ent.LineWeight != cLw ) {
                        if ( HasErrors )
                            sb.Append( " / Lineweight" );
                        else
                            sb.Append( "    Lineweight");
                        HasErrors = true;
                    if ( HasErrors )
                        Ed.WriteMessage( sb + " not ByLayer" + Environment.NewLine );
                            HasErrors = false;
                                HasErrors = true;
                                if ( HasErrors )
                                else
                                HasErrors = true;
                                if ( HasErrors )
                                else
                                HasErrors = true;
                            if ( HasErrors )
        Trans.Commit();
Report like
MTEXT(9DB7B)    Linetype not ByLayer
POINT(9DB7C)    Color / Linetype not ByLayer
POINT(9DB7D)    Color / Linetype not ByLayer
POINT(9DB7E)    Color / Linetype not ByLayer
LINE(9DB82)    Linetype / Lineweight not ByLayer
LINE(9DB83)    Linetype / Lineweight not ByLayer
LINE(9DB84)    Linetype / Lineweight not ByLayer
SOLID(9DB85)    Linetype not ByLayer
SOLID(9DB86)    Linetype not ByLayer
MTEXT(9DB87)    Linetype not ByLayer
POINT(9DB88)    Color / Linetype not ByLayer
POINT(9DB89)    Color / Linetype not ByLayer
POINT(9DB8A)    Color / Linetype not ByLayer
LINE(9DC3F)    Linetype / Lineweight not ByLayer
LINE(9DC40)    Linetype / Lineweight not ByLayer
LINE(9DC41)    Linetype / Lineweight not ByLayer
SOLID(9DC42)    Linetype not ByLayer
SOLID(9DC43)    Linetype not ByLayer
MTEXT(9DC44)    Linetype not ByLayer
POINT(9DC45)    Color / Linetype not ByLayer
POINT(9DC46)    Color / Linetype not ByLayer
POINT(9DC47)    Color / Linetype not ByLayer
Guess could put in a count to see how many entities were found.
« Reply #53 on: July 22, 2008, 07:09:30 PM »
Here is a counting one, and I changed it so that it only prints one string to the command line, which I thought might speed it up, which it seems like it did a little.
    Entity Ent;
    StringBuilder MainString = new StringBuilder();
    StringBuilder sb;
    bool HasErrors;
    RXClass rxc;
    long Count = 0;
                    HasErrors = false;
                        HasErrors = true;
                        ++Count;
                        if ( HasErrors )
                        else {
                            ++Count;
                        HasErrors = true;
                        if ( HasErrors )
                        else {
                            ++Count;
                        HasErrors = true;
                    if ( HasErrors )
                        MainString.AppendLine( sb.ToString() + " not ByLayer");
                            HasErrors = false;
                                HasErrors = true;
                                ++Count;
                                if ( HasErrors )
                                else {
                                    ++Count;
                                HasErrors = true;
                                if ( HasErrors )
                                else {
                                    ++Count;
                                HasErrors = true;
                            if ( HasErrors )
        if ( !Count.Equals( 0 ) ) {
            MainString.AppendLine( Environment.NewLine + "Found " + Count + " entities not ByLayer." );
            Ed.WriteMessage( MainString.ToString() );
        Trans.Commit();
Results like
Found 57978 entities not ByLayer.
Glenn R
« Reply #54 on: July 23, 2008, 04:56:42 AM »
Which might not be what a particular company wants Tim...
Glenn R
« Reply #55 on: July 23, 2008, 04:58:29 AM »
I would suggest the same way as the CAD Standards Checker does. This way, you can email the report to the insultant and they know what to fix. If you do it like audit, it's not very friendly.
David Hall
« Reply #56 on: July 23, 2008, 10:35:09 AM »
I think I have it worked out in my head how to check the fonts and layers, I'm going to try and code that up today.
sinc
« Reply #57 on: July 23, 2008, 10:51:38 AM »
Is the goal for this project to create something that works in Vanilla Autocad only?
I'm only asking because the newer vertical products like Revit and Civil-3D use Styles to incorporate most of their standards, so the majority of standards checking in those products would involve Styles.  And because of the way Styles work, it can be difficult to analyze objects to see if they are "ByLayer", or things like that...
Maybe Styles throw too big a monkey-wrench into things...?
vegbruiser
« Reply #58 on: July 23, 2008, 10:55:22 AM »
...Maybe Styles throw too big a monkey-wrench into things...?
I think maybe you've answered your own question?
« Reply #59 on: July 23, 2008, 10:57:13 AM »
What would that look like Glenn?  I don't have a dws file around, and have tried to set it up once, but didn't like it, so I canned that idea.
I don't have any real verticals on my machine, so I wouldn't know how to code to check styles.  Maybe that will be in the second generation of the routine.
