Author Topic: acet-attsync  (Read 3647 times)
Ron Heigh
acet-attsync
« on: September 10, 2004, 10:35:01 AM »
I'm trying to use the acet-attsync function in a lisp routine, but it isn't a valid command.  Once I use the ATTSYNC command in the drawing, the acet-attsync command becomes valid in my lisp routine?
Any ideas why this might be occuring?
Ron Heigh
acet-attsync
« Reply #1 on: September 10, 2004, 11:12:01 AM »
I fixed it by adding this to my acad.lsp file.
(if (not acet-attsync) (command "attsync" "" (command)))
Stupid solution for a stupid problem.
acet-attsync
« Reply #2 on: September 10, 2004, 11:28:22 AM »
Try this :
(if (not Acet-Getvar) (vla-load AcetUtil.fas))
Ron Heigh
acet-attsync
« Reply #3 on: September 10, 2004, 05:10:33 PM »
Thanks, but that didn't do it either.
I tracked the function to the BATTMAN.ARX file.
I added it to my startup suite and now all is good.
Ron Heigh
acet-attsync
« Reply #4 on: September 10, 2004, 05:19:30 PM »
better yet.
(arxload "battman")
