Author Topic: critique, advice, opinions appreciated  (Read 7497 times)
Bethrine
« on: July 14, 2008, 01:41:53 PM »
I'm working on an old, no longer going to happen, drawing from a friend and trying to improve it and practice and improve my skills on it in the process. Any thoughts are appreciated. I am also going to work my way through my 2007 CAD book, again, and post that stuff. It should keep me in the groove, provide laughter and enjoyment and make some of you shake your heads and cringe.  :evil: All opinions, thoughts, critiques welcome.  :police:
Bethrine
Re: critique, advice, opinions appreciated
« Reply #1 on: July 14, 2008, 01:45:26 PM »
Below is the original I recieved.
Spike Wilbury
« Reply #2 on: July 14, 2008, 01:46:20 PM »
maybe if you posted as PDF (or other readable) it will let others to review your drawing...
Bethrine
« Reply #3 on: July 14, 2008, 01:48:38 PM »
I have to see if I am set up to plot to PDF. I'll make that my current project. :)
Spike Wilbury
« Reply #4 on: July 14, 2008, 02:02:57 PM »
Bethrine,
1. What are you doing on that drawing, to improve yourself ?
2. Is that going to be a base drawing?
3. Do you have a basic layering system?.
4. Do you know about pen weighs?
etc.....
Bethrine
« Reply #5 on: July 14, 2008, 02:21:44 PM »
Bethrine,
etc.....
I am applying what I learned at my previous job providing me with practice at all kinds of things as well as trying to improve it visually and find more that I need to learn.
Yes, it's a base drawing for what I hope will look professional when I am through and will have also provided me with the knowledge and ability to do it again.
I have a basic idea of a layering system and am also hoping to improve on that too.
I know about pen weights but definitely have a ways to go in order to fully understand them and the best way to use and apply them and how they should look on the final product.
Below is a DWF, I am having set up problems with the Adobe plotting "system". It's the original I recieved.
Bethrine
« Reply #6 on: July 14, 2008, 02:24:15 PM »
I should've put this in "Teach Me"  :ugly:  ...hey, I'm a bullfrog!!!  :-D
Spike Wilbury
« Reply #7 on: July 14, 2008, 02:32:51 PM »
What you need, in my own personal opinion it is to use, a set of (hardcopy or pdf's) drawings and draw from there, that way you will have an idea of what it is needed.
Bethrine
« Reply #8 on: July 14, 2008, 02:37:26 PM »
Yes, I am still going to work on the PDF output. My next step is to understand what Autospool is and if I should be using it. Then I have to figure out if I actually have the driver which I know little about except that I need them.  :-(
Here's the DWF of what I have done so far...
Spike Wilbury
« Reply #9 on: July 14, 2008, 02:49:49 PM »
I review both drawings, and I can tell you they are not coming good or right, sorry.
As I said before, use a real sample, and copy the drawing, exactly... why you don't do that? -
Bethrine
« Reply #10 on: July 14, 2008, 03:57:11 PM »
What do you mean by real sample?
Spike Wilbury
« Reply #11 on: July 14, 2008, 04:01:45 PM »
A set of construction drawings from a real project, something that can give you a better idea...
Bethrine
« Reply #12 on: July 14, 2008, 04:05:14 PM »
I don't have access to those currently and this was a real project that just didn't end up being built.
Spike Wilbury
« Reply #13 on: July 14, 2008, 04:05:58 PM »
Bethrine
« Reply #14 on: July 14, 2008, 04:12:02 PM »
Downloaded and looking around....thanks!....
