Author Topic: Zigzaq prints as dashed line  (Read 4003 times)
craigr
« on: July 11, 2008, 08:27:00 AM »
I have a dwg that has a 'box' around an Energy Recovery Wheel. The Box is drawn as a Zigzag linetype set at .1 size. When printed here at our office, it prints fine - Just as drawn, but when printed in one of our other offices, it prints as shown in my attachment.
What can our other office do to make their printer print the linetype correct?
craigr
Re: Zigzaq prints as dashed line
« Reply #1 on: July 11, 2008, 11:44:30 AM »
Are they plotting to the same plot device?
Perhaps plot them a DWF instead and then printer, driver, linetype files do not come into play.
craigr
« Reply #2 on: July 11, 2008, 03:36:53 PM »
They are printing do a different type printer, which I suspect is a 'el cheapo' from Walmart. - Before you say it... They won't be getting a different one, as what they print is for their own use only and there is only the 2 of them.
If they can't update their printer driver, I suspect they are SOL or they will have to FORCE me to change the Zigzag for a linetype that will print okay on their printer.
craigr
« Reply #3 on: July 11, 2008, 04:08:27 PM »
I take it the linetype displays properly on their computer
craigr
« Reply #4 on: July 11, 2008, 04:10:22 PM »
Yes, it displays fine but prints wrong.
I have confirmed that they are using an 'el cheapo' printer. I have talked with our IT guy and he plans to look at their printer driver and see if he can figure it out.
craigr
« Reply #5 on: July 11, 2008, 05:32:11 PM »
craigr
Try a DWF yet?
craigr
« Reply #6 on: July 14, 2008, 07:21:29 AM »
I KNOW they would NEVER go for printing it twice. - Once to DWF then to the printer.
Not an option.
Thanks anyway,
craigr
Bethrine
« Reply #7 on: July 14, 2008, 01:19:49 PM »
Not an option.
Thanks anyway,
craigr
Thought I would point out that a DWF takes seconds and is a file, not on paper that should print to paper exactly as it looks in the file dwg.
My apologies if you already knew this. It just seems silly not to DWF it if it works and is fast. JMO
« Reply #8 on: July 14, 2008, 08:18:25 PM »
Not an option.
Thanks anyway,
craigr
You send them the DWF they print the DWF
no problem, unless the problem is they just can't print  :angel:
