Author Topic: viewport layer freeze  (Read 5579 times)
kc27315
« on: June 24, 2008, 03:06:17 PM »
I am using Autocad Civil3d 2009 now.  Is there a way to freeze a particular layer in every viewport in the drawing?  I don't want to have to go to each layout tab and individually viewport-freeze the particular layer in every viewport manually.
Thanks for any help.
kc
Re: viewport layer freeze
« Reply #1 on: June 24, 2008, 03:55:39 PM »
Command: vplayer
Enter an option [?/Freeze/Thaw/Reset/Newfrz/Vpvisdflt]: f
Enter layer name(s) to freeze or <select objects>: layername
Enter an option [All/Select/Current] <Current>: all
kc27315
« Reply #2 on: June 24, 2008, 03:57:54 PM »
That trick used to work when I was using Autocad 2008, but now that I'm using 2009, it doesn't work anymore.
« Reply #3 on: June 24, 2008, 04:13:26 PM »
Here is a workaround for now:
(defun younameit (laylist option / doc ct ln)
  (setq doc (vla-get-activedocument
      (vlax-get-acad-object)
ct  (vla-get-activelayout doc)
  (vlax-map-collection
    (vla-get-layouts doc)
    '(lambda (x)
       (if (/= (vla-get-name x) "Model")
   (setvar 'ctab (vla-get-name x))
   (foreach ln laylist
     (if (tblsearch "layer" ln)
       (command ".vplayer" option ln "all" "")
       (princ (strcat "\nYour layer " ln " does not exist!"))
  (vla-put-activelayout doc ct)
(younameit '("layname1" "layname2" "layname3") "freeze");;Where the last option is Freeze/Thaw/Reset/Newfrz/Vpvisdflt
« Last Edit: June 24, 2008, 05:59:40 PM by ronjonp »
kc27315
« Reply #4 on: June 24, 2008, 05:09:57 PM »
I'm sorry, I don't know how to use the code.  Do I copy and paste the entire text that's in the code field into the command line?  If so, what do I do then?
Thank you,  kc
« Reply #5 on: June 24, 2008, 05:28:25 PM »
The layer freeze may have no impact, unless A) you have independent layer set on in your C3D ambient settings
and or B) the object display component is set to use unique layers in the style definitions.
« Reply #6 on: June 24, 2008, 05:59:12 PM »
Thank you,  kc
You need to load the upper portion of the code into acad.
Then modify this line to include the layer name(s) to freeze in the viewports and paste it in the command line:
kc27315
« Reply #7 on: June 25, 2008, 09:35:21 AM »
Thank you.  I don't know how to load the upper portion into acad.  It's ok though.  Maybe it's just gonna be easier to go to each layout tab and freeze them individually.  I appreciate your effort though, and I wish I wasn't so dumb.
kc
« Reply #8 on: June 25, 2008, 09:44:18 AM »
What are the names of the layers you want to freeze?
dfarris75
« Reply #9 on: June 25, 2008, 09:48:59 AM »
kc
Here now. That sort of self-defeating language won't be tolerated. Now say this with me: "I can figure this out because I'm good enough, I'm smart enough, and doggonit, people like me." :love:
kc27315
« Reply #10 on: June 25, 2008, 02:36:13 PM »
Thanks dfarris75, much appreciated!
ronjonp, the three layers I want to freeze this time are C-IMP, Construction Lines, and C-XSPOT.
« Reply #11 on: June 25, 2008, 02:52:05 PM »
Download the file and drag it into your ACAD screen.
« Reply #12 on: June 25, 2008, 11:42:14 PM »
Kicking and Screaming
kc27315
« Reply #13 on: June 27, 2008, 03:18:23 PM »
Well, I kicked and screamed for a while, but I tried it and it works.  Thanks so much!  I appreciate all your help.
kc
« Reply #14 on: June 28, 2008, 12:12:23 AM »
Glad you got it working :)
