Author Topic: ObjectARX Documentation For Visual Studio 2008  (Read 4045 times)
Re: ObjectARX Documentation For Visual Studio 2008
« Reply #1 on: June 22, 2008, 07:51:05 AM »
Are those the same docs that comes with the SDK?
csharpbird
« Reply #2 on: June 22, 2008, 10:05:32 PM »
YES
« Reply #3 on: June 22, 2008, 10:17:30 PM »
I thought it was different .. Isn't the download the help files for incorporation into the VS ide ?
« Reply #4 on: June 23, 2008, 12:51:49 AM »
It’s the same docs that come with the arx2009 SDK (not the .CHM files) , there is an installer for VS.
I like using the H2 viewer though http://helpware.net/mshelp2/h2viewer.htm
« Reply #5 on: June 23, 2008, 02:42:10 AM »
Ahhhh, so!
Thanks Dan.
csharpbird
« Reply #6 on: June 23, 2008, 09:06:58 PM »
You can view the help files in "Microsoft Visual Studio 2008 Documentation" or "Dynamic Help" in Visual Studio 2008.
« Last Edit: June 23, 2008, 10:17:13 PM by csharpbird »
« Reply #7 on: June 23, 2008, 09:30:57 PM »
My only concern is that you are redistributing something that normally requires one to agree to an EULA.  :-o
