Found this in the autocad help guideQuoteTypically, the intersections of adjacent wide polyline segments are beveled. No beveling is performed for nontangent arc segments or very acute anglesDoing this I can replicate your problem, but there is no solution to it.
By definition an acute is any angle less than 90 degrees.
I was pretty sure Tracy was a cute angel.
Thanks Deeg, but I might just thin the Pline a little, then it might not look so obvious... I'll try that tomorrow, and any other suggestions that may turn up.Cheers one and all
Quote from: jonesy on June 04, 2008, 01:09:17 PMThanks Deeg, but I might just thin the Pline a little, then it might not look so obvious... I'll try that tomorrow, and any other suggestions that may turn up.Cheers one and allTwo plines for the outer boundaries with a solid hatch?
Quote from: Matt W on June 04, 2008, 01:22:49 PMQuote from: jonesy on June 04, 2008, 01:09:17 PMThanks Deeg, but I might just thin the Pline a little, then it might not look so obvious... I'll try that tomorrow, and any other suggestions that may turn up.Cheers one and allTwo plines for the outer boundaries with a solid hatch?Offset a zero width pline as many times as it takes at a short distance until the proper width is achieved? Naaaa.A multiline with the same properties as above would achieve the desired result, and be easly moved, stretched, and wutnot.Just thinkin out loud here...
