Author Topic: Conversions....  (Read 1278 times)
MvdP
Conversions....
« on: May 06, 2008, 09:40:19 AM »
I created a huge code about 10 years ago and it is working since then.
Now i want to modify this code.(Also for learning others ways to get info and so on...).So i modified it to code below.
But i get errors...
Msg> bad argument type: numberp: nil
And f.i. the first thing it is supposed to do is setting "schaalecht" and this is not being set.
I think it has something to do with conversions or am i missing something here ,but i can't seem to figure this one out.
(He are small parts of the "old" code of how to get info)
(start_list "list_schaal")
(setq displistschaal
(list
   ;123456789012345678901234567890
   "   1:20                   04"
   "   1:50                   05"
   "   1:100                  06"
(mapcar 'add_list displistschaal)
(end_list)
(start_list "list_formaat")
(setq listformaat
(list
   ;123456789012345678901234567890123456789012345678901234567890123456789012345
   " ISO A2 (420.00 x 594.00 MM)                 A2                 594   420"
   " ISO A1 (594.00 x 841.00 MM)                 A1                 841   594"
   " ISO A0 (841.00 x 1189.00 MM)                A0                 1189  841"
   " User 1 (594.00 x 1051.00 MM)                594x1051           1051  594"
(mapcar 'add_list listformaat)
(end_list)
(action_tile "list_schaal"  "(setq schaalecht (nth (atoi $value) displistschaal))(schaalid)(list_schaal_action $value)" )
(action_tile "list_formaat" "(setq formaatecht (nth (atoi $value) listformaat))"  )
(defun schaalid (/)
  (setq sch (atof (substr schaalecht 6 5)))
  (setq schnr (atof (substr schaalecht 27 2)))
(defun formaatid (/)
 (setq kader (substr formaatecht 46 8))
 (setq rbx (atof (substr formaatecht 65 4)))
 (setq rby (atof (substr formaatecht 71 4)))
(defun bereken ()
  (setq mode_o (smodes '(("CMDECHO" 1)
("BLIPMODE" 0)
("ATTREQ" 1)
("REGENMODE" 0)
("EXPERT" 4)
("TEXTEVAL" 1)
  (setvar "aperture" 5)
  (setq schaal (rtos sch 2 0))
  (setq annotschaal (strcat "1:" schaal))
  (setq limlo (list (* sch -20.0) (* sch -20.0)))
  (setq limrb (list (* sch (+ 10.0 rbx)) (* sch (+ 10.0 rby))))
  (setq lo (list 0 0))
  (setq rb (list (* rbx sch) (* rby sch)))
(He are small parts of the "new" not working code of how to get and set  vars same action tile as "old" code)
(list
   "1:20"
   "1:50"
   "1:100"
  (end_list)
  (setq listformaat
(list
   "ISO A2 (420.00 x 594.00 MM)"
   "ISO A1 (594.00 x 841.00 MM)"
   "ISO A0 (841.00 x 1189.00 MM)"
  (end_list)
(defun schaalid (/)
((= schaalecht "1:20")   (setq sch "20")   (setq schnr "04"))
((= schaalecht "1:50")   (setq sch "50")   (setq schnr "05"))
((= schaalecht "1:100")  (setq sch "100")  (setq schnr "06"))
((= formaatecht "ISO A2 (420.00 x 594.00 MM)") (setq kader "A2")      (setq rbx "594") (setq rby"420"))
((= formaatecht "ISO A1 (594.00 x 841.00 MM)") (setq kader "A1")      (setq rbx "841") (setq rby"594"))
((= formaatecht "ISO A0 (841.00 x 1189.00 MM)")(setq kader "A0")      (setq rbx "1189")(setq rby"841"))
« Last Edit: May 06, 2008, 11:57:04 AM by MvdP »
