Author Topic: ADT.cui  (Read 4136 times)
daron
ADT.cui
« on: May 05, 2008, 11:00:41 AM »
For some reason when I type cui at the command prompt, the cui opens but tells me it is unable to open file '...\...\...ADT.cui'. I've tried opening other cui's to no avail. As a last resort I tried to run a repair on ACA 2008. I'm not sure what more to do, except ask if anyone has a working ADT.cui file they could post to see if I can get it working again? Thanks. Any other ideas would also be appreciated.
daron
Re: ADT.cui
« Reply #1 on: May 05, 2008, 12:17:29 PM »
Well, restore point worked.
TimSpangler
  • CAD Naked!!
Re: ADT.cui
« Reply #2 on: May 05, 2008, 12:28:13 PM »
Are you running more than one version on your system '09?  I understand that can cause curruption to the cui. for erlier releases.?
ACA 2015 - Windows 7 Pro
daron
Re: ADT.cui
« Reply #3 on: May 05, 2008, 12:33:16 PM »
I am, but haven't had this problem before. '08 and '06. Both are still loaded. I try only to use '08. It seems to work now, though. Thanks.
