How would I go about the following?
I often find that I need to do a straight swap for two blocks.A bit like the BLOCKREPLACE command, but I dont want to it to affect all my blocks globally just the ones Im working on.The way I currently acheive this is to draw a line to each blocks insertion points(centre) and then move them about,using the endpoint point of the line for my insertion point and delete the lines once Im done.Am I the only one who draws these guidance lines?
![Smiley :)](http://www.theswamp.org/Smileys/black/smiley.gif)
I dont think that BLOCKREPLACE command was very developed by Autodesk,it has numerous bugs,it doesnt handle attributes to well,theyre either misplaced or at a different scale ratio with their associated block.I was previously thinking that BLOCKREPLACE command will be a really helpful feature well done Autodesk,I think not!
