Author Topic: issues with x,y extraction and alteration coding, please help.  (Read 4889 times)
alanjt
  • Standby for witty remark...
(setq base_point (getpoint "\nSpecify base point: "))
(setq ptascii_x (car base_point))
(setq ptascii_x (rtos ptascii_x 2 2))
(setq ptascii_y (cadr base_point))
(setq ptascii_y (rtos ptascii_y 2 2))
(setq point_calc (rtos (- ptascii_y 4.5)))
Specify base point: *Cancel*
bad argument type: numberp: "531632.7"
« Last Edit: April 11, 2008, 01:42:17 PM by alanjt »
Dropbox
Re: what's wrong with this code?
« Reply #1 on: April 11, 2008, 01:30:01 PM »
Your trying to subtract from a number that you already converted to a string:
« Reply #2 on: April 11, 2008, 01:32:33 PM »
Whats wrong with the subject line of your post?
alanjt
Re: issues with x,y extraction and alteration coding, please help.
« Reply #3 on: April 11, 2008, 01:43:34 PM »
thanks ronjonp i knew it was something silly. Se7en, is that a better subject line, sorry about being ambiguous?
Dropbox
daron
« Reply #4 on: April 11, 2008, 01:57:55 PM »
Would "why can't I subtract a real from a string" be a better subject line, 7? :-D
« Reply #5 on: April 11, 2008, 02:04:09 PM »
I dunno...To be honest, I never read the post (Nothing personal, I saw a response and assumed it was taken care of).
A good subject line is for your benefit not mine (well it is in a obscure way.). You get better help if people know what the question is before they read the actual question.
« Reply #6 on: April 11, 2008, 02:10:10 PM »
A: Se7en cannot understand it as it relates to the subject matter presented by the question.
Q: Do I win the prize?
Q: Is there a prize?
« Reply #7 on: April 11, 2008, 02:13:09 PM »
How should i know?! Did you answer correctly?
I didn't know there was a contest.
daron
« Reply #8 on: April 11, 2008, 02:40:54 PM »
What was the original name?
alanjt
« Reply #9 on: April 11, 2008, 02:55:56 PM »
Dropbox
« Reply #10 on: April 11, 2008, 03:22:05 PM »
I'll take that as a resounding NO on both accounts
daron
« Reply #11 on: April 11, 2008, 03:57:02 PM »
:-o Hmm. I see nothing wrong with that title. I've seen worse. At least that let's us know that you have tried something and it's not quite working.
alanjt
« Reply #12 on: April 11, 2008, 04:08:29 PM »
i'm not trying to make an enemy here, but seriously Se7en?
Dropbox
« Reply #13 on: April 11, 2008, 05:28:14 PM »
Not `trying'? Your not `trying' by posting a private message in a public forum?
But to answer your question; whats wrong with me trying to explain where im coming from so you dont take what i say the wrong way (get angry)?
What you just did (post a PM in public) is NOT cool, not cool by any means. If you had a problem with what i PM'ed you, you should have either reported me to a moderator or just wrote me back saying that you didnt not want to speak with me.
Am i angry? Yeah kinda.
*Was* i angry? Not at all.
Was i trying to make you angry? Never!
Did you make an enemy? Not with me.
(but we will see how other people react to you posting PMs.)
« Reply #14 on: April 11, 2008, 05:36:32 PM »
John, since you chastised Alan publically perhaps your link and reasoning may have been better posted as well .. takes the same energy and everyone benefits.
