Author Topic: Zero Margins and settings  (Read 4288 times)
« on: April 07, 2008, 07:45:58 AM »
Since Se7en introduced me to his zero margin setup I've been quite happy with the results. Last week I ran into a bit of a problem though. Every time I printed a half size ( 11X17 ) the printer would chop off the bottom and right side of the print. After going crazy for a couple of days trying to figure this out I finally did! *woot* There is a setting in the printer driver, ( HP Laser ) that some how got turned off. After changing it all is good again.
Re: Zero Margins and settings
« Reply #1 on: April 07, 2008, 08:22:25 AM »
I have that very same printer in my office and i had heard rumors of that happening to some people here as well (weird coincidence) but i havent had any time to devote to it yet. Thanx for doing my leg work (That is to say, if people here are having the same problem as you)!
« Reply #2 on: April 07, 2008, 01:37:58 PM »
Mark,
Do folks use Inked Area or Edge of Paper as your 0,0 for Paperspace?
« Reply #3 on: April 07, 2008, 01:48:15 PM »
Mark,
With the few drivers I have available to me the only one that mentions either of these is the Oce, I *think* I have it set to inked area.
« Reply #4 on: April 07, 2008, 02:44:26 PM »
I was talking about Options>>Plot and Publish>>Specify Plot offset relative to:
(lower right quadrant)
« Reply #5 on: April 07, 2008, 02:58:58 PM »
Sorry, it's set to printable area.
« Reply #6 on: April 08, 2008, 06:53:41 AM »
Here's another one to watch out for. Yesterday I was plotting a set of drawings and noticed the plotter was adding a 1/2" to both the top and bottom of the sheet thus making my ANSI D 23x34. OOP's!! A simple setting fixed the problem.
