Author Topic: Ghostscript: The Thread  (Read 21293 times)
Re: Ghostscript: The Thread
« Reply #15 on: April 17, 2008, 01:44:26 PM »
Thank You Mark!!!
Now I need a switch to print upside down, as the rotation is upside down.  I think I saw an option for that, so I'll see if I can find it again, but if you/anyone knows it off the top of your heads I'm will to accept the help.   :-)
« Reply #16 on: April 17, 2008, 02:45:31 PM »
I have seen, in my searches, that the orientation for landscape could be 1 or 3.  I used 1 and now it is not upside down.  Thanks a lot.
Not to see if I can expand on this, and have them all put into one pdf file based on the numbers.  This might be a pipe drawing, but if it works that will be great.
  • Custom Title
« Reply #17 on: April 17, 2008, 03:43:43 PM »
I use pdftk for that because I get files from multiple sources.
  • Custom Title
« Reply #18 on: April 17, 2008, 03:44:08 PM »
« Reply #19 on: April 17, 2008, 05:24:07 PM »
Does this mean that it can't be done with ghostscript?  I see that if you list all the names, then it will, but I want it to find all the pdfs in the current directory and create a single pdf out of them.  I can't seem to find a way to do it without listing all the files to convert.  I don't know how to use batch files, so this is a learning experience, and I can't seem to find the correct resources.
  • Custom Title
« Reply #20 on: April 17, 2008, 07:10:31 PM »
I'm not saying that because I'm not sure, I just like the pdftk works. :)
http://www.theswamp.org/index.php?topic=21802.msg265987#msg265987
Krushert
  • FREE BEER Tomorrow!!
« Reply #21 on: May 29, 2008, 02:35:13 PM »
Okay so I got some time to give this Ghost Script a try to what it can do.
Well I manage to get a "_.at" File with this inside
-dCompatibilityLevel#1.4
A7.1
SERIES-A7.1.plt
For my batch file, I started with Mark's version and ended up with this.
rem @echo off
rem Ted Krush
rem 05/29/2008 - testing PDFs
rem
%echo off
echo looking for .plt files ....
echo.
echo.
echo Converting to pdf ....
echo.
for %%f in (*.plt) do call "C:\Program Files\GhostScript\ghostscript-8.62\lib\ps2pdf" %%f ..\output\%%~nf.pdf
echo.
echo.
echo.
echo.
echo.
echo.
echo All done!
I am assuming that the at file is a log file of what went wrong.  Where did I screw up at and where do I go to figure it out.
« Reply #22 on: May 29, 2008, 04:45:38 PM »
Why are you calling the BAT file when you can/should get in the habit of calling the program...
Set up GS the right way; -i.e. at min. set up your environment vars, and then you can use this for all your conversion needs.
for %%f in (*.plt) do gswin32c -dSAFER -r600 -sDEVICE=pdfwrite -o "%%~nf.pdf" "%%f"
I created a VBS file instead of a BAT file, this way i can drag and drop files to that script to be converted (i dont have to convert all the files).
Krushert
« Reply #23 on: May 29, 2008, 05:37:01 PM »
I DON'T KNOW!
The way I have it set up was the most I got of it after trial and error.  I tried similar code that you guys have posted and got nothing but the dos shell.  Mater of fact I just tried you code above and got the same results
Noticed I downloaded the latest version and no where can find the exe file and the only gswin32 files that I found found are the 4 files in the image below.
Also I see mentioin of making a make file?  But I can't
This is what I want.  What is the difference besides the file extensions?  How do draft it up?  After a quick search, it is a Visual Basic and I have to say I know nothing about Visual Basic
  Huh You only have to drag and drop some of them to to convert all of them?
Again I am fish out of water and all I am doing is flopping arround and making a big mess.
« Last Edit: May 29, 2008, 05:40:03 PM by Krushert »
« Reply #24 on: May 29, 2008, 05:42:39 PM »
I would still like to see the ability to capture multiple plots and put them into a single PDF file
« Reply #25 on: May 29, 2008, 06:24:59 PM »
<snip>
Again I am fish out of water and all I am doing is flopping arround and making a big mess.[/i]
*lmao* Yes you are! We need to talk tomorrow. I will get you all set up. 15 minutes tops.
BTW, your looking at the source code.
Keith, That's no problem. I will show you how tomorrow.
Im going home now.
Maverick®
« Reply #26 on: May 29, 2008, 06:37:01 PM »
Im going home now.
'Nite John boy.
« Reply #27 on: May 30, 2008, 10:28:52 AM »
This is the essence for putting several files into one.
gs -sDEVICE=pdfwrite -o output.pdf file1.ps file2.ps file3.ps
« Reply #28 on: May 30, 2008, 10:32:53 AM »
Cool .. now I just need to automate it in my plotting script
« Reply #29 on: May 30, 2008, 01:21:26 PM »
Please post how you automate, as I couldn't figure it out.
