Yea, uhm, I think all of this has gone a bit over my head!
You guys are an invaluable resource, but I'm not sure that the problem is worth all of this attention.
I was hoping that there was some setting somewhere, or some copy/paste type of solution. I can just as easily leave the sheet number out of the "Line Number".
To clarify the EXACT problem, (prolly should have done this first I guess) the "Line Number" circle thingy is simply a tool that will be used by a technician when he wants to follow a wire from one sheet to the next. There will be instructions at the end of a wire that tell where it is continued in the drawing. Usually (but not always) on a different sheet, and at some line. Now, the sheet number is in the title block, so putting it in the Line Number is really kind of redundant anyway, but it is the way the legacy (drawn by hand) drawings are done and I was trying to kind of duplicate that as a courtesy.
Not worth a bunch of code that I don't understand and would take a week to perfect, I am in a production type environment so time is of the essence. I have the only set of drawings in the whole wide world sitting on my desk, so if anything goes wrong with the machine, I have to give them up so it can be fixed.
That leads me to my next question...but I'll start a new post for that one after I do a search to see if it's been covered before...
Thanks to all who racked thier brains over the problem, I sincerely appreciate the effort. And someday soon, I'm going to get into some of this code so that the next time I have a similar issue and you guys throw some code my way, I'll understand better what it is that it does. For now, I must press on with the drawing!!
Thanks again guys & gals!!!!!
