Author Topic: 3d Model of a Pole type Building?  (Read 8140 times)
SDETERS
« on: March 31, 2008, 05:45:55 PM »
Is there a place to go to download 3D models of a pole type steel buildings.  The brand name that we have around here is Morton Building and or Sturdi built.
I am looking for one that is 24 x 40.  Is there a website or do different companies carry different style of there buildings?
Maverick®
Re: 3d Model of a Pole type Building?
« Reply #1 on: March 31, 2008, 08:00:12 PM »
Whatcha lookin for?  Framing 3d or the whole shebang?
Maverick®
« Reply #2 on: March 31, 2008, 11:20:59 PM »
SP isn't really set up to do Pole barns but..... here's my try.  I couldn't figure out a way to do the roof purlins..... yet
Josh Nieman
« Reply #3 on: March 31, 2008, 11:39:49 PM »
wow, even put in the translucent skylight panels... fancy schmancy.
Maverick®
« Reply #4 on: April 01, 2008, 12:39:24 AM »
gotta keep the rats happy
SDETERS
« Reply #5 on: April 01, 2008, 08:23:36 AM »
Cool That will do the trick  What file format can you export out for me?
I am doing some layout work for my dad
He wants to put a Building like that up and I want to put in a 3d world with his trees and garage and part of the house so he can get a feel for the location and room for all of the stuff he want to put in it.
Maverick®
« Reply #6 on: April 01, 2008, 09:43:59 AM »
There is a .dxf down at the bottom there.  That won't work?
Guest
« Reply #7 on: April 01, 2008, 09:48:15 AM »
Probably not.... the DXF is 2D.
SDETERS
« Reply #8 on: April 01, 2008, 09:49:33 AM »
I did not see that let me check it out   :oops:
Thd dxf is only 2d can I get a sat file?
I have autocad 2007  to open files in.  Thanks
Maverick®
« Reply #9 on: April 01, 2008, 10:39:58 AM »
k. Give me a few minutes.
Maverick®
« Reply #10 on: April 01, 2008, 10:55:05 AM »
Try this.
Josh Nieman
« Reply #11 on: April 01, 2008, 10:59:31 AM »
Try this.
Nice model, looks good, functional layers...
Comes in to the right scale/units.
The only drawback to the model is that all layers are set to color "white" and each individual object is overridden to be the colors you see, which is backwards to the "proper" way "most" people use Autocad.  No biggie since this is easy to fix.  Select all - set color ByLayer, then make the layers whatever color you want...
That and it exports everything as polyface meshes rather than solids, but I'm pretty sure M2S.lsp would take care of turning them from meshes to solids.
I like it.  Softplan exports pretty decent with good usable file... nice to know I guess.
The grade beams come in as 4 separate objects mitered at the corners, with the slab being a whole other object (making 5 total than make up the slab)
All girters are one object, per wall.  All fascias are one object.
Again, not problems... just noting... it seems like conversion problems that used to exist are nearly eliminated these days, the more I see with current technology... seemed like stuff was absolutely horrible 5+ years ago and couldn't work with anything.
Maverick®
« Reply #12 on: April 01, 2008, 11:04:43 AM »
With V14, that I just got, I can export to 3ds or.... I think POV... or something like that.  Would those work better?
SDETERS
« Reply #13 on: April 01, 2008, 11:14:24 AM »
The DXF is nice  sweet kicks  butt   thanks a bunch
Where is the m2s.lsp at?  Where can I download that?  Thanks
Josh Nieman
« Reply #14 on: April 01, 2008, 11:19:21 AM »
It's a fairly popular one.
This is the first link I found from Google: http://www.cadtutor.net/forum/archive/index.php/t-1408.html
