Author Topic: Modelspace coordinates from paperspace viewports?  (Read 2887 times)
hardwired
« on: March 31, 2008, 09:33:24 AM »
How can i access the modelspace coordinates from paperspace viewports?
Is there a quick way or is it more complex than a simple property or in-built function?
David Hall
  • Automatic Duh Generator
Re: Modelspace coordinates from paperspace viewports?
« Reply #1 on: March 31, 2008, 10:04:21 AM »
what exactly are you trying to do?  find the limits of the VP as it relates to MS?
hardwired
« Reply #2 on: March 31, 2008, 10:23:34 AM »
Yeah basically. I want to create a rectangle (polyline) in modelspace to indicate where the viewport in paperspace in 'looking at'..
« Reply #3 on: March 31, 2008, 11:54:34 AM »
If you don't mind a lisp solution, here is one I wrote and Alan (CAB) fixed.
http://www.theswamp.org/index.php?topic=9461.0
surveyor_randy
« Reply #4 on: April 03, 2008, 08:22:00 AM »
This post got me curious.  Is it possible to set the center of a viewport with modelspace coordinates in VBA?
Bryco
« Reply #5 on: April 03, 2008, 10:04:09 AM »
Zoom and zoomcenter for that Randy.
The rectangle has been covered in past posts and  a solution for 2d given perhaps the lisp gives a better solution for isoviews
surveyor_randy
« Reply #6 on: April 03, 2008, 01:07:13 PM »
Thanks for the help!
« Reply #7 on: April 03, 2008, 02:44:50 PM »
One could copy the original viewport and then use the chgspace command, this will insert the viewport rectangle into the model.
