We have upgraded lately from LT2005 to LT2008.
I first set up my workstation. Migrated all of my customizations into LT2008.
Once I got mine all set up, I exported my settings using the 'Migrate Settings, Export Settings' that comes with LT2008. - Everything went great. I then used the 'Import settings' to set up everyone else's workstations. Again, everything went great.
Since then, I have added several macros / icons and have exported the settings to new .zip files.
One of our Engineers got a new workstation a while back and when I tried to again import my files to his new workstation, it 'craps out', I mean the program doesn't run. It IS in the Task Mangager, but doesn't appear on screen. So I started exploring and discovered that my Exported file is corrupted. So, I used older revs of my backup files and all imported fine. So I determined that there is something wrong with my installation and can no longer use that utility, which is not a good thing.
I don't want to uninstall / reinstall my CAD because I would lose my newer settings. But, I can no longer pass those updates on to my coworkers.
Now today, another coworker got a new workstation and I can't even export my settings. So I tried importing my Original export and even IT won't import. So I went to another workstation to create an export file and now it won't export either. The third workstation I tried, I was able to export the settings and import them to the new workstation. So, he is up and running but without my newest macros / icons.
I have posted my earlier problems with this on the AutoDesk Web site and go nothing.
Have any of you used this program and found problems with it?
When the program worked it was GREAT! Much easier than the old way.
Any help would be greatly appreciated.
craigr
