Author Topic: Exposing Objects in VLISP  (Read 6295 times)
ML
« on: March 17, 2008, 05:08:51 PM »
Hi
I was asked if I can expose the objects from Land Desktop in VLISP.
I know that in VBA, I can connect to the type library: AutoDesk Land 4.0 Type Library
then all of the objects are exposed in the VBAIDE
From what I read, I only need to path to The type (tlb) library in VLISP
(vlax-import-type-library
    :tlb-filename "C:\Program Files\Autodesk Land Desktop 2006\LandAuto46.tlb"
    :methods-prefix ""
    :properties-prefix ""
    :constants-prefix ""
Now, I have never really used VLISP before, so I believe I have made the connection but I am not sure how to get to the Land Desktop objects.
Any suggestions?
Also, is there a way to run code in VLISP with apploading it with each change?
Thank you,
Re: Exposing Objects in VLISP
« Reply #1 on: March 17, 2008, 06:01:41 PM »
Here's an example of how to get the AeccApp, AeccProject, and the Point Database. Note that this works with all LDT versions (ok, most. You may need to adjust it for 2004 & 2005 as I didn't have those to check). Good Luck! Note, too, that I do not use the import-library feature. I did at one time but  found I really didn't need it (it jsut allows you to call the proper & methods a wee bit easier).
  (if (and (setq key (vl-filename-base (vlax-product-key)))
   (setq vers
  (atoi (substr key
6
(- (vl-string-position (ascii ":") key) 5)
   (setq aeccVer (cond ((= vers 138) "2")
       ;;LDT3
       ;;((= vers 2008) "4");;LDT2004???
       ;;((= vers 3008) "4");;LDT2005???
       ((<= vers 4008) "4")
       ;;2006, this should use the actual values for LDT 2004 & 2005
       ;;as this will allow non-LDT's to continue
       ((= vers 5008) "6")
       ;;2007
       ((or (= vers 6008);;LDT
    (= vers 6018);;C3D LDT companion
"7")
       ;;2008
       ((alert "LDT version not supported!") nil)
   (setq aeccString (strcat "Aecc.Application." aeccVer))
      (setq aeccapp  (vla-getinterfaceobject
       (vlax-get-acad-object)
       aeccstring
    aeccProj (vlax-get aeccapp 'activeproject)
    aeccPts  (vlax-get aeccProj 'cogopoints)
« Reply #2 on: March 17, 2008, 06:06:40 PM »
ML
« Reply #3 on: March 17, 2008, 06:28:37 PM »
Jeff,
Looks good!
I tried this:
(Defun C:ActProj ()
   (setq vers
  (atoi (substr key
6
       ;;LDT3
       ((= vers 5008) "6")
       ;;2007
"7")
       ;;2008
       aeccstring
But I am getting an error:
malformed list on input
Did I do something wrong?
Thank you
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #4 on: March 17, 2008, 07:45:26 PM »
Jeff,
Looks good!
I tried this:
(Defun C:ActProj ()
Did I do something wrong? .
Thank you
view the code in the VLIDE editor and balance the parenthesis ; you're missing a couple
Called Kerry in my other life
I live at UTC + 13.00
ML
« Reply #5 on: March 18, 2008, 09:16:32 AM »
Jeff
I got it!
Thank you; it worked great
I didn't bother connecting to the type library either as your code got the job done.
Still, I may take a look at that for other things later.
jbuzbee
« Reply #6 on: March 18, 2008, 11:16:26 AM »
ML,
When working with vertical collections, release the collection object as soon as possible, i.e. not at the end of a routine or in a clean up *error* function: as soon as you get the information you need - release it.  Don't know why, that's just the best way to handle it.
Also, if you try to use ObjectDBX on an external database to access collections and objects I've found some limitations there as well.  Have a look at this thread:
http://www.theswamp.org/index.php?topic=17758.0
James Buzbee
Windows 8
ML
« Reply #7 on: March 18, 2008, 11:25:43 AM »
Hey Jb
Unfortunately I am not much of a LISP programmer, I can do a few things.
However, I am certainly open to learning more.
I looked at your code and for the most part, I did get it.
I also understand what you are saying about realizing the objects.
In VBA:
Object = Nothing
Let me as you this:
Is there a way in VLISP to run your code without saving it, apploading it, then typing in the command?
In VBA, we can run the code right from the editor, I was wondering if VLISP also had that same function?
Also, once I have the connection to the a type library in VLISP, is there a way to expose the collection in VLISP?
Thanks!
jbuzbee
« Reply #8 on: March 19, 2008, 11:12:14 AM »
Yes - type VLIDE at the command line, press F1 and start learning!  :wink:
Yes, there is a function in VLISP called "vlax-dump-object" that returns all the properties and methods of said object.  Very usefull when working with undocumented vertical objects and collections.
Use:
(vlax-dump-object 'obj T)
'obj is a valid activex object
the last argument: if nil only returns properties, if T returns properties and methods.
James Buzbee
Windows 8
ML
« Reply #9 on: March 19, 2008, 04:55:34 PM »
Hey JB
It didn't take a whole lot to figure out
Ctrl + Alt + E  LOL
I actually put in
(vlax-dump-object(vlax-get-acad-object) T)
Yesterday and it only returned the objects for the ACAD App
No properties or methods.
ML
« Reply #10 on: March 19, 2008, 04:59:54 PM »
Actually
It did give me the properties and methods.
In VBA:
Let's take Preference for example; it exposes all of the settings in Preferences
This does not
I'm sure there is a way.
I am really more into VBA, I was just dabbling with VLISP
; IAcadApplication: An instance of the AutoCAD application
; Property values:
;   ActiveDocument = #<VLA-OBJECT IAcadDocument 04fc7f84>
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00c2eb8c>
;   Caption (RO) = "Autodesk Map 3D - [Drawing1.dwg]"
;   Documents (RO) = #<VLA-OBJECT IAcadDocuments 0e58e9c0>
;   FullName (RO) = "C:\\Program Files\\Autodesk Land Desktop 2006\\acad.exe"
;   Height = 998
;   HWND (RO) = 132408
;   LocaleId (RO) = 1033
;   MenuBar (RO) = #<VLA-OBJECT IAcadMenuBar 0e58ece4>
;   MenuGroups (RO) = #<VLA-OBJECT IAcadMenuGroups 0111d46c>
;   Name (RO) = "AutoCAD"
;   Path (RO) = "C:\\Program Files\\Autodesk Land Desktop 2006"
;   Preferences (RO) = #<VLA-OBJECT IAcadPreferences 0e58e92c>
;   StatusId (RO) = ...Indexed contents not shown...
;   VBE (RO) = #<VLA-OBJECT VBE 0b2a27a4>
;   Version (RO) = "16.2s (LMS Tech)"
;   Visible = -1
;   Width = 1288
;   WindowLeft = -4
;   WindowState = 3
;   WindowTop = -4
; Methods supported:
;   Eval (1)
;   GetAcadState ()
;   GetInterfaceObject (1)
;   ListArx ()
;   LoadArx (1)
;   LoadDVB (1)
;   Quit ()
;   RunMacro (1)
;   UnloadArx (1)
;   UnloadDVB (1)
;   Update ()
;   ZoomAll ()
;   ZoomCenter (2)
;   ZoomExtents ()
;   ZoomPickWindow ()
;   ZoomPrevious ()
;   ZoomScaled (2)
;   ZoomWindow (2)
« Reply #11 on: March 19, 2008, 05:02:31 PM »
Preferences is another object, so to see what is there you need to dump that object.  What you did in VBA can be done in Lisp with ActiveX, with regards to the properties and methods of objects.
ML
« Reply #12 on: March 19, 2008, 05:05:43 PM »
Hey T.
OK, I see what you are saying, thanks
I will try dumping Preferences.
When you are saying with Active X, do you mean that I will need to connect to a type library of some sort from VLISP?
I saw how to connect to a type library but I could not expose the objects in it in VLISP
« Reply #13 on: March 19, 2008, 05:15:03 PM »
To use ActiveX in Lisp you just have to load the arx file, which (vl-load-com) called from a lisp file once per session will do.
« Reply #14 on: March 19, 2008, 05:30:11 PM »
Mark,
If you really want to see how to use the methods & properties for LDT by using the type-library, go download SincPac for LDT. Sinc made this available years ago and has a bunch of neat routines. And they are not compiled into a fas or vlx so you can see what he did. It is all pretty advanced stuff, but it sounds like that's the road you are headed down. :-)
But, to use ActiveX you do not NEED to use the type-library. You just need to do as I showed using vlax-get (or vlax-get-property), etc.
Using the (vlax-import-type-library) allows you to do this:
(vla-get-activealignment aeccdoc)
instead of this:
(vlax-get aeccdoc 'activealignment)
