Author Topic: Shape keeps disappearing  (Read 2267 times)
Guest
« on: February 13, 2008, 09:30:02 AM »
I've got a linetype with a shape embedded into it.  When I close and reopen the drawing, the shape is gone from the file.  The line that had the embedded shape now shows "dashes" where the shape used to be.
Any ideas on how to fix this?  I'm using a standard shape (ltypeshp.shx) from Land Desktop - I think it might even be a Vanilla standard.
M-dub
Re: Shape keeps disappearing
« Reply #1 on: February 13, 2008, 09:32:19 AM »
Does a regen make them reappear?
LTscale?
File Search Paths?
Guest
« Reply #2 on: February 13, 2008, 09:41:55 AM »
LTscale?
File Search Paths?
No.
It's set correctly.
Also set correctly.
NEXT!!!  :-)
M-dub
« Reply #3 on: February 13, 2008, 09:45:52 AM »
LTScale might be set correctly, but did you try changing it to anything else?
Guest
« Reply #4 on: February 13, 2008, 10:01:16 AM »
Yup... No dice!
M-dub
« Reply #5 on: February 13, 2008, 10:02:44 AM »
I'll scratch my head on it a bit more, but right now, I got nuthin'.
« Reply #6 on: February 13, 2008, 10:05:31 AM »
Waaaaaaay out there guesses but
(1) what layer are the shapes on?
(2) is a clip active?
(3) do you have viewres maxed out?
(4) what shademode is active (wireframe, hidden, yada)?
(5) are there any pigs in space (entities far far far away from the origin and/or the majority of the drawing elements)?
{shrug}
Josh Nieman
« Reply #7 on: February 13, 2008, 10:07:07 AM »
I'm sorry, man, between MP and MDub, all my guesses were taken care of.  I had thought of MDub's suggestions and MP's suggestion of making sure you have 2D Wireframe set... that one gets me often.
M-dub
« Reply #8 on: February 13, 2008, 10:10:04 AM »
When you add a line with said shape in it, do you ever get a message at the command prompt?  What about when you re-open the drawing?
DaveD
« Reply #9 on: February 13, 2008, 11:15:55 AM »
Maybe another dumb question, but are you sure the shape file is on one of your support paths?
