Author Topic: VBA in Excel  (Read 11914 times)
David Hall
  • Automatic Duh Generator
VBA in Excel
« on: January 23, 2008, 09:18:05 AM »
I have never written anything in VBA for excel.  that being said, I could use some help with a function to purge a spreadsheet.  Any takers?
David Hall
Re: VBA in Excel
« Reply #1 on: January 23, 2008, 09:18:52 AM »
000011815   UNS Electric Inventory   STICK SHOT GUN CHANCE SINGLE   Each   DCLASS   EF-KSAFETY 1   7   $202.57
000011815   UNS Electric Inventory   STICK SHOT GUN CHANCE SINGLE   Each   DCLASS   EF-LSAFETY 3   7   $202.57
000011815   UNS Electric Inventory   STICK SHOT GUN CHANCE SINGLE   Each   DCLASS   EF-NSAFETY 4   7   $202.57
000011816   UNS Electric Inventory   GRIP SMALL   Each   DCLASS   EF-KSAFETY 3   7   $79.60
000011816   UNS Electric Inventory   GRIP SMALL   Each   DCLASS   EF-LSAFETY 12   7   $79.60
000011816   UNS Electric Inventory   GRIP SMALL   Each   DCLASS   EF-NSAFETY 2   7   $79.60
« Last Edit: January 23, 2008, 09:24:34 AM by CmdrDuh »
Guest
Re: VBA in Excel
« Reply #2 on: January 23, 2008, 09:22:56 AM »
Huh?  Purge as in like, selecting everything and pressing the DEL key??  :?
David Hall
Re: VBA in Excel
« Reply #3 on: January 23, 2008, 09:26:56 AM »
Yes  hahaha,
OK no, I need to search Column A for each number, like 11815 in above example, then go over to the H column and compare the $$ amount to the one below.  Delete the row which is < the other.  Make sense?
Guest
Re: VBA in Excel
« Reply #4 on: January 23, 2008, 09:30:41 AM »
Yes  hahaha,
Yup.  Can you post a small example, like what you have above (only in XLS format, of course).   :-)
David Hall
Re: VBA in Excel
« Reply #5 on: January 23, 2008, 09:31:31 AM »
I am trying to figure out how to grab A# and A#+1 .  From there the > comparison is pretty easy.  Deleting the row is the next challenge.  I also thought about using N (integer) to keep up with where I am row.count wise
Edit: Attached XLS file
« Last Edit: January 23, 2008, 09:36:39 AM by CmdrDuh »
David Hall
Re: VBA in Excel
« Reply #6 on: January 23, 2008, 09:37:14 AM »
Sorry it took so long, I didn't know you couldn't post xls file directly.
Guest
Re: VBA in Excel
« Reply #7 on: January 23, 2008, 09:40:53 AM »
Yes  hahaha,
What if, like in your example, the dollar amounts are the same?
David Hall
Re: VBA in Excel
« Reply #8 on: January 23, 2008, 09:44:47 AM »
Delete one of the rows.  This is a very small part of an inventory/vendor spreadsheet that our warehouse has with the people that order the parts.  So there might be 2 vendors with the same price, or 10 w/ the same, or 10 and 9 have the same price, but 1 is higher.  Im trying to narrow it down for the upcoming budget season so I can use the biggest amount to CYA in the budget.
David Hall
Re: VBA in Excel
« Reply #9 on: January 23, 2008, 09:45:53 AM »
BTW, this SS is 35000+ lines long and I spent 4 hours yesterday manually deleting the extra rows.  I only made it through ~1000 before I went crazy.
Greg B
  • Tell me a Joke!
Re: VBA in Excel
« Reply #10 on: January 23, 2008, 10:19:53 AM »
A good starting point is to record a macro.  Then you can modify it to fit your needs.
Basically start recording and do it manually what you want done and take a look at the code.
David Hall
Re: VBA in Excel
« Reply #11 on: January 23, 2008, 10:21:24 AM »
How do you record something when the process takes place in your mind?  How do you look at 2 rows, and delete the smaller one?
Greg B
  • Tell me a Joke!
Re: VBA in Excel
« Reply #12 on: January 23, 2008, 11:05:52 AM »
This of course is where it gets modified.
At least you'll have to code to grab a row and delete it.  You throw in an
if x > y then
rows.delete yadda
Greg B
  • Tell me a Joke!
Re: VBA in Excel
« Reply #13 on: January 23, 2008, 11:06:57 AM »
First hard code, then modify to allow for variables.
David Hall
Re: VBA in Excel
« Reply #14 on: January 23, 2008, 11:09:32 AM »
ok, now I see where your going.  The problem is I know very little about VBA in excel.  How do I grab a row?  Im thinking there should be an activerow, but I haven't found it yet.  Once I figure out how to grab a row, the > logic should be pretty straightforward
